Question about Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum
Steam doesn't work
Turns on but doesn't work. No steam, no spray
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
Detergent will not spray out
It must be blocked by minerals use CLR repeat process if needed leave it plugged in
Mar 09, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop S3501A doesn't make steam
My shark wouldn't steam with the head on so I cleaned the holes with a paper clip and then poured CLR through it and it is working now.
Aug 02, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
Water will not spray out and pick up
My steam vac wont spray out the cleaning products.
Feb 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Steam and spray
the heater may be clogged. You will have to take it aprt, pull the hoses off, using somothing small, clean out the prots that the hoses hook to. After that, blow thru it if you can to see if air comes out. Then after it is put back together, put a mix of vinegar and water in and let it run thru until it works good again. Calicum and such plug up the works and just need to be cleaned out.
Feb 13, 2008 | Sharper Image Turbo SM420 Handheld Steam...
Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum Logo
32 people viewed this question
Top Sharper Image Vacuums Experts
JoeVacs
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
