Question about Chevrolet 1955 Chevy Bel Air 1/24 Red
Has new battery, starter,alternator, still will not start
    President:
  • Chevrolet Master
  • 1,851 Answers
You do not say what engine you have and what your expertise is.
Try getting a book on the timing and distributor to spark plug relationship.
Set the timing
check the firing order is correct.
check the points are set properly and in good shape
new rotor and cap if needed.
Posted on Jul 12, 2010
Trying to figure out alternator fuse number on 2010 Dodge journey sxt don't see the word alternator on fuse box have new battery and alternator but still goes click click when trying to start it
The alternator fuse has nothing to do with that . If starter solenoid is just clicking an you have a new battery it's more then likely battery cables or connections . To test the starter circuit you need to do voltage drop testing . The alternator doesn't start working till the vehicle starts an is running . Starter Voltage Drop
Oct 02, 2016 | 2010 Dodge Journey SXT
My car will not start. The battery is new and has a full charge and turns everything on when I turn the key but when I try to start it, it will not do anything not even clicking noise.
if the battery is good it is NOT the alternator. the alternator charges the battery, if it won`t start with a new battery the alternator does nothing to affect the situation. check voltages at the starter motor connections for proper voltages even the wires that the ignition switch supplies power to. if you have proper voltages at the starter you can try hitting the starter while someone tries to start the car. if it starts the starter is worn internally and will have to be replaced.
Aug 05, 2015 | 2003 Hyundai Santa Fe
New battery new alternator wont start ?
I'd check for bad or corroded contacts/cables from battery to starter (If your vehicle is older than 14 years). If that looks good I'd be suspicious of the solenoid in your starter sticking(will probable need a new starter).
Sep 04, 2014 | Cars & Trucks
93 Toyota Pickup, new starter,Battery,alternator, wont start
Check connections in wiring. Could be a ground fault
Feb 28, 2013 | Cars & Trucks
Batterylight on after rev new battery and alternator
who put in the alternator and battery. when you rev up the motor the alternator is push more volts. are the wires all hooked up right. there is a starter relay . but i think a wire is touching or is not hooked up right
Nov 21, 2012 | 2004 Ford Taurus
My 1999 mitsubishi diamante will not start. I got a friend to jump it but it still would not start. I took the battery out and took it to autozone to charge it. But autozone would not charge it because...
It sounds like you need a new starter. If you hear the starter click when you turn the key to start, replace your starter since you already replaced the battery. You might want to have your alternator checked out, or when you get your car started, test the battery terminals with a multimeter. You should have around 14 volts with the car running. If not, you will need a new alternator. The alternator won't keep the car from starting though, unless the battery was drained because it wasn't charged. Even then it is the battery keeping the car from starting.
If the starter is not clicking, check your fuses under the hood. If all checks out, you may have a bad ignition switch.
Jul 02, 2011 | 1999 Mitsubishi Diamante
I have 91 4 runner new battery & alternator & new starter
did you check all the fuses and the main fuse under the bonnet try to give thr starter a few taps with hammer not hard if starts then it is brushes in starter ,does light come on on dash if you put key in on position
May 17, 2009 | 1988 Honda Accord 4 Door
Replaced battery, started 5 - 6 times, new battery ded.
Nope, but they are usually near the battery, solenoid or starter (where main service wires are)
Mar 22, 2009 | 1987 Ford Ranger
Chevrolet 1955 Chevy Bel Air 1/24 Red Logo
83 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
