Question about Creative Labs ZEN Vision:M Digital Media Player
Zen Vision M - Wont Sync All Files And Then Freezes??
Hi, my player has been acting up for the last few months, Ive managed to get it playing again by formating it and uploading the new firmware but when it was syncing all my music back on it stopped about a third the way through and froze. I had to reset it and Now when i try and sync it maybe puts one or two tracks on and the same will happen. Ive tryed my friends player (Zen vision exactly the same) and it syncs everything on perfectly and i have tryed it on two pc's.. I even have some albums on it that are missing songs?? I am very close to giving up as i dont have the patience anymore, please help!!!
  • Stereo-D Feb 19, 2008
    Yup, have tryed almost everything at this stage..waiting to hear back from creative but its lookin like i bought a very expensive piece of useless black plastic :(
  • asad_palekar Feb 29, 2008
    i too have a similar prob.. exactly the same problem.. any solutions for it??
    President:
  • 4,402 Answers
Have you tried doing a clean?
sounds like the hard drive may be going on them.
Posted on Feb 19, 2008
  • Cary Farah
    Cary Farah Feb 19, 2008
    yeah it's bad hard drive then you might be able to replace with flash drive.
Zen Micro 8gb freezes during transfers -6gb model works fine!
Now convinced this is bad boot sector on the HD and searching for a repair utility (the inbuilt zen reformat option doesn't sort it) or have to replace HD with new one.
Nov 13, 2009 | Creative Labs Zen Micro MP3 Player
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Can't put music on my zen vision m 30 gig
it might be the files ur using maybe there not compatable or maybe corupt
Jun 23, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen 4GB Freezes and wont turn off
no fix - obviously a piece of junk - certainly not going to Buy support for junk
thanks anyway
andie
Jan 15, 2009 | Creative Labs ZEN Vision:M Digital Media...
It won't transfer my zen vision M songs from my computer
I've been able to solve the problem I had with transferring files to my Zen Vision M.
I uninstalled all components of Media Source 5 and Zen Vision M Series Explorer on my PC. I then reinstalled them again. I also rolled back to Windows Media 10 (as I recently upgraded to v 11) and unchecked Sync with Zen Vision M in tools/options/devices on WM player. I then run the Clean up in recovery mode on the Zen. When the PC restarts after the installation of the software it will ask for you to connect the player. The PC should now successfully transfer files to the player.
Hope it works for you too.
Apr 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
There must be a way to retrieve data!!!
There is no way to run recovery and keep the files - backup the files first, if possible. keep them on your computer just in case the problem persists.
Feb 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision freezing
What you need to do is check the firmware. By doing so, set the device on "Disk Mode" and try to reinstall your firmware. Also make sure to back up all your files before doing so. If thats not the case, then it could be the battery life. Most of these reported cases all have to do with the battery performance. Freezing is the most common case of battery dysfunction. Make sure you get that checked out.
Don't panic!
bananaboy101
Feb 09, 2008 | Creative Labs Zen Vision Digital Media...
Zen Vision:M videos out of sync..EVERYTIME!
ZVM cannot handle the AC3 audio so the AVI files need to have mp3 audio. I have a lot of videos that I have converted over the years that I want to play on the ZVM. In order to check compatibility I have been using gspot. I just open the program, drag and drop the file, and get all the details I need in about 5 seconds.
Sep 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
221 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
