Question about GE Profile JGSP48 Gas Kitchen Range
My GE Profile Gas range JGSP48 will not cook on BAKE setting on works on Low or Hi BROIL..
  • 375 Answers
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list.
Posted on Jul 15, 2010
Gas oven won't work on "bake" setting
If the hot surface ignitor is very red in the middle of it when turnig on the oven, it is faulty. Replace it.
Jul 18, 2010 | GE Kitchen Ranges
GE Profile Gas Range, oven doesn't heat up on any
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Bake does not work
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 11, 2009 | GE Profile JGSP48 Gas Kitchen Range
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven takes longer than expected to light
You probably have a bad gas valve, part # WB21T10014, unless the new igniter is defective. If your broil works, you can prove this by temporarily hooking the broil igniter in the bake spot. Hope this helps!
Jan 01, 2009 | GE Profile JGSP48 Gas Kitchen Range
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Oven lighting
Hi thanks for your question. no you cant light with a match. the bake igniter has to come on. check the igniter. thanks
Oct 14, 2007 | GE Profile JGSP48 Gas Kitchen Range
Ge oven jpbp90
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
Oct 15, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGSP48 Gas Kitchen Range Logo
385 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
