Question about Kohler K-3489 Cimarron Comfort Height Elongated Toilet With Left-Hand Trip
The last part of the flush is really loud. Is this how it works or is there an issue with the toilet
  • 105 Answers
I would say that this is a good thing simply because it sounds as though it's evacuating very well,..just what you want it to do,....
Posted on Jan 31, 2010
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
How do i fix airlock in toilet pipe inlet?
Try feeding water in from toilet end, or increasing water feed presureand holding valve open at toilet end. The more difficult way is to find the high point in the system before toilet and fit a bleed nipple, this may mean dismantling interior.
Jan 03, 2016 | Cars & Trucks
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
I have a jacuzzi espree (EZ36959) toilet which was installed in November of last year. It has worked fine until November of this year. It will not flush solid waste. I have to add hot water and wait...
did any one run camera threw? This usually means obstruction.If you have really hard water.holes around rim could be restricted.cure is muratic asid.be very careful.rarely,a pluged vent stack.once I found a big dip in a long drain line slowing flush.
Dec 18, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
I fitted a saniflo plus about 3 months ago engineer been out 5 times even changed unit last engineer said it was toilet paper stuck in tiny hole at bottom of motor he said it was due to not flushing...
This could be a problem with the capacitor which drives the blade and impeller. If it goes bad it will pump water only but when solids are flushed, it will jam the blade and cause it not to spin. You may have to replace the capacitor/condenser.
Nov 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Kohler K-3489 Cimarron Comfort Height Elongated Toilet With Left-Hand Trip Logo
71 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
