Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Loud houling sound coming from freezer GE GSH25JSTA
  • 111 Answers
That would be the little fan in the freezer that moves the air around that makes it frost free, replace the fan
Posted on Jan 31, 2010
  • wehdejim Sep 19, 2011
    This is an electronic card problem in the back of the freezer. It is a well-known problem in these GE side-by-sides.
Freezer thaws and refreezes
HI.DO BASICS FIRST .CLEAN CONDENSER UNIT FIRST THOROUGHLY.INTERMITENT FAULT IS ALWAYS A BIT DIFFICULT TO DIAGNOSE.TRY IT IF OK U HAVE CRACKED IT BUT IF SAME THEN C WEATHER THE MOTOR AND CON/UNIT IS WARM WHEN DEFROSTING IF COLD IT COUD BE A LAZY DEFROST TIMER OR T/STAT THEN HEATER AND FAN.GOOD LUCK ALI
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Model GSH25JSTA SS. Intermitten howling noise from below the ice maker. I pull out the ice bucket and it sounds as if it is coming from the fan. Noise fluctuates when removing a panel in that area. What do...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 22, 2011 | GE Refrigerators
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
GE side by side has a whinng sound goes loud and low
Need to unplug and remove the back panel in freezer to see if there is a defrost problem or whats going on with evaporator fan. Let me know for sure if your model is a HSM25IFTSA so we will be on same refrigerator. Thanks, Sea Breeze
Apr 20, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Mar 22, 2009 | GE Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
OUR GE SIDE BY SIDE MODEL# GSH25JSTA-SS IS MAKING A STRAINING LOUD NOISE. HELP
Hello.
Can you tell where the sound is coming from, underneath or inside? If it is coming from underneath make sure the coils are clean and the fan below is blowing. Usually the compressor will labor under these conditions. Let me know if these all check out ok and I will go over some other things..
Dec 05, 2008 | Refrigerators
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
316 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
