Question about HP Office Equipment & Supplies
After a jammed document, our copier will only print if fed through the feeder. It is the photosmart pcsx It is HP309a series
  • 542 Answers
Issue The automatic document feeder (ADF) does not pick up any sheets of paper. Solution Follow these steps to resolve the issue. It might not be necessary to complete all steps to resolve the issue. Step one: Check the paper in the ADF The condition or amount of loaded paper might prevent the ADF from picking up and feeding sheets through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. Load these special media types on the scanner glass.
  3. Make sure the loaded paper in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • No staples or clips attached
  4. Try the copy or fax job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the input tray from the ADF, and then open the ADF cover. Figure 1: Remove the input tray and open the ADF coverafter a jammed document, our copier will only - c01441053.gif NOTE: You product might vary in appearance from the one show in the figure, but the procedure is the same.
  2. Lift the wide, green lever on the pick assembly, and then carefully rotate the pick assembly toward the open ADF cover until it stops. Figure 2: Rotate the pick assemblyc01441054.gif
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the 2 catch hooks located to the left and the right of the roller.
    • Make sure the stack stopper, located between the top and bottom rollers, fits within the double slots above the bottom roller. The stack stopper should move freely within the double slots when you lift and lower the assembly. Figure after a jammed document, our copier will only - c01441055.gifper and 2 catchc01441055.gif
  4. Return the pick assembly to its original position.
  5. When you turn on the product, the top roller resets to its original position above the separator pad. There should be a gap between the separator pad and after a jammed document, our copier will only - c01623721.gifr. Figure 4: Gap between separator pad and the top rollerc01623721.gif If there is no gap between the ADF top roller and the seperator pad, press the Power button (c01602202.gif ) to turn off the product.
  6. Wait three to five seconds, and then press the Power button (c01602202.gif ) to turn on the product. The ADF rollers reset to the correct positions.
  7. Close the ADF cover, and then reattach the ADF input tray.
  8. Try the copy or fax job again.
    1. Remove the input tray from the ADF, and then open the ADF cover. Figure 5: Remove the input tray and open the ADF coverc01441053.gif NOTE: You product might vary in apafter a jammed document, our copier will only - c01441054.gif the one show in the figure, but the procedure is the same.
    2. Lift the wide, green lever on the pick assembly, and then carefully rotate the pick assembly toward the open ADF cover until it stops. Figure 6: Rotate the pick assemblyc01441054.gif
    3. Lightly dampen a clean, lint-free cloth with after a jammed document, our copier will only - c01441056.gifer, and then squeeze any excess liquid from it.
    4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use a small amount of isopropyl (rubbing) alcohol on the cloth instead. Figure 7: Separator padc01441056.gif
    5. Return the pick assembly to its original position.
    6. Close the ADF cover, and then reattach the ADF input tray.
    7. Try the copy or fax job again.
    Solution four: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause
    • Dirty paper pick rollers provide insufficient grip to pick up paper from the ADF tray.
    • Paper with glossy effect or high sheen can be slippery, causing a pick error by the ADF pickup rollers.
    For more info browse the below URL:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01622793&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3737195
    Revert back for more assistance.
Posted on Jan 31, 2010
  • Rajesh Pai
    Rajesh Pai Feb 07, 2010
    I have not received any update. If your problem got resolved, Please give your valuable feedback/rating on the same.
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass?
Oct 16, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Brother MFC-8480DN Printer jammming
try to clean the document feeder, i think there so many scratch of small piece of paper that why the printer is paper jam.
Feb 07, 2014 | Brother MFC 7840W Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Document Jam
check the photo sensor for the paper fed at the doc feeder roller section you can blow this out with air or try to clean it off you could also check the actuatot arm to see if the spring has com off.. usually its down to the paper dust on the sensor
Jun 16, 2009 | Office Equipment & Supplies
The printer says Paper Jam even there is no paper in it
Please try to clean paper jam area with referring to instruction manual. You printer needs cleaning...
May 04, 2009 | HP Office Equipment & Supplies
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
29 people viewed this question
Seeker5211
Seeker5211
