Question about Sebo X4 Bagged Upright Vacuum
My sebo keeps cutting out while I use it the turns back on when I move the lead about. Its over 5 half years old?
    President:
  • 389 Answers
Sounds like the flex is damaged. This happens most often either right near the plug or where the flex enters the handle. There may be no damage visible externally, but still the copper wire inside can be broken. You say that moving the flex about makes a difference, so you will know where the problem is. If the damage is indeed at one end, then you can simply cut the flex and re-wire it. If you need to have someone do it for you, get a firm quote as it may be cheaper to fit a complete new handle (there's no labour cost involved because the handle just slides in). I hope this helps!
Posted on Jan 31, 2010
Can't get the Sebo S-class filtration off to replace it. I bent the wire down, didn't move much. I tried to pull it off but, it didn't budge.
The filtration cone just pulls out. That's why there's a looped piece of plastic on it at the base of it. The spring wire keeps it in place so that the door can be locked back on.
Aug 27, 2015 | Sebo X4 Bagged Upright Vacuum
Tip
Useful Tips for Sebo's X1 Bagged upright vacuum.
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.
When it comes to filter replacement, the standard cone/tube shaped filter can actually be cleaned by the Sebo if only just for a short moment just to get rid of any attached dirt the filter has accumulated. By removing the filter tube, the auto stop clip comes down, but by lifting your finger with this clip upwards and your other hand holding the bin door, the door can actually be locked back into position as it would normally. Then using the standard upholstery t shaped tool, clean the tube leaving it free of any dust and dirt contained in the tube. Once the tube has been cleaned you can take out the bin door and install the filter back in. Sadly the foam motor filter on the top hood cannot be cleaned or washed and has to be replaced.
If the filter tube however is completely stained and you dont have a free spare one to fit, the filter can actually be removed by removing the tie clips on the top and bottom of the holder. Wash the filter and dry in a tumble dryer - EBay in the UK sometimes sell filter squares which can be tied and locked to the cylindrical tube. Once the filter is dry you can then tie it up to the grid again and if the ties get lost, small computer wire ties are a suitable replacement.
Another feature of the Sebo X which has only just come to light recently with Sebo's user videos is use of the dry cleaning powder. Although Sebo don't actually tell you, by manually rubbing the powder into your carpet with just your fingers rather than raking it in on the top surface you'll get more out the first application of rubbing the powder in and letting it get a better chance of removing actual heavy stains. If you don't want to rub that powder in manually, remove the top hose by unlocking it where it meets the bag dirt channel on the left hand side of the machine at the top. (right hand obviously if you are facing the Sebo) then the Sebo X can be used as a rolling  brush to rub the powder in. After the 30 minutes minimum waiting time, lock the hose back into the X and vacuum up as normal.
This facility of removing the hose/thus cutting the suction is also very useful to rub in bicarbonate of soda into your carpets if you own pets. Bicarbonate of soda is an ideal natural odourizer which will maintain clean areas. Sebo's DuoP dry powder is ideal to do this as well for general stain protection if you like to keep your carpets clean.
The paper bags can also last a lot longer if the dirt your Sebo has collected remains half way at the top rather than naturally falling to the bottom of the bag.My X1 does this with new carpet fluff. Take the crevice tool and push the tool into the top opening of the bag to push the dirt GENTLY down - this will give you extra longevity on the bag used as well as not having to replace it so often.
There are ways to make your Sebo X1 cost effective!
on Mar 28, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Seems like a loose connection ..
A 15 year old vacuum cleaner is more economical to replace rather than repair.
Jan 09, 2015 | Sebo X4 Bagged Upright Vacuum
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
My sebo cleaner keeps almost cutting out but comes back on again after a couple of seconds. I.ve checked for blockages and changed the bag and filters.
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Oct 07, 2010 | Sebo Vacuums
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Machine keeps cutting out intermittenly
My Sebo Air Belt C2 Total. The automatic electric cable wire won't stay out when pulled, it just springs back. When I'm hoovering I have to wrap the wire around the small wheels so that it doesn't shoot back in the machine.
Oct 18, 2009 | Sebo Air Belt C2.1 Bagged Canister Vacuum
My SEBO vacuum cleaner keeps cutting out which seems to suggest an dodgy electrical connection...any ideas ?
If it just cuts out then comes back on after a while, it might be overheating.
Sep 22, 2009 | Sebo Vacuums
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
272 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
