Question about Whirlpool Dryers
Lint has built up inside the 3 plastic fins of Whirlpool Duet
Lint has built up inside the 3 plastic fins (baffles--?) inside the dryer. How do I remove the fins/baffles in order to clean them out?
  • 1 more comment
  • mwaid82 Jan 31, 2010
    Model GEW9200LW0 Whirlpool Duet, purchased new in 2002.
    Lint screen is in the lower front panel, accessible at the bottom of the door.
  • mwaid82 Feb 01, 2010
    Your solution worked! Thanks for the helpful directions!
    We also took the front cover off and cleaned all the accumulated lint out from the inside "guts" of the dryer; also took the black cover off of the fan and discovered it was half-full of lint.
    Thanks again...I am afraid we were awfully close to having a fire!
    Anyone reading this--go clean the lint out of your dryer. Just cleaning the lint screen is not enough!!
  • 619 Answers
What is the model Number. Does your lint screen go thru the top or is it in the door.
Posted on Jan 31, 2010
Testimonial: "Great directions...solution was easy to follow and exactly what I needed!"
  • Ricky Harrelson
    Ricky Harrelson Jan 31, 2010
    There should be 3 screws at the back of the top section. Remove these screws going across back then slide top to rear and lift off. From here you will be able to see the screws holding the baffles. Hope this has been helpful.
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
The wedges inside dryer, can they be removed and put back? I hear lots of change and things inside of them.
The baffles yes take off the top loosen the screws don't take them all way out rotate and shake loose baffle repeat for others
Sep 22, 2014 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Lent and dryer debris building up under tumbler fin. can it be removed to clean
Yes the baffles could be removed to clean them by removing the lint filter,in the top where the filter goes are 2 phillips head screws,remove them,use medium sized straight blade screwdriver and place it in the seam between the top in and front panel and pop up the top,them pivot back against the wall(dont worry it is hinged in the rear and wont fall off). You will see the drum and can remove the screws that screws that hold the baffles in place,to rotate the drum to get to each baffle rotate it by hand in a counterclockwise direction.
Gene
Aug 07, 2011 | Whirlpool LGR8648L Gas Dryer
My frigidaire dryer start and a few seconds later an alarm sounds and E68 appears.
Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful when you pull it out, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint (use soft toothbrush), and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build up of lint was shorting the two contacts, and this was screwing up the electronics.
Sep 12, 2010 | Frigidaire AEQ6000ES Electric Dryer
1 of 3 fins on inside is loose & hanging by 1 screw.
Access to the bottom of the baffles for tightening the screws requires the lifting of the top cover which also requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are positioned on the top for tightening.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Hair/Lint collecting on the Baffles of the dryer
I once heard you can periodically spray "Spray Starch" on the baffles themselves to alleviate lint and hair buildup. If you can prevent the unwanted particles from building up on the baffles theoretically they should be trapped in the dryer's lint collector.
Mar 01, 2010 | Whirlpool Dryers
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
HE3 dryer drum metallic noise while spinning.
The baffels are pretty easy to take out.
You will need a quarter inch nut driver.
First, you remove the top cover of the unit off by removing the 3 screws in the back. then each baffle will have 2 quarter inch screws and you can access them easily once the top cover is off.
Best of luck :)
Sep 13, 2009 | Kenmore Dryers
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
Dryers Logo
553 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
