Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The washer quits spinning sometimes, mostly when
The washer agitator quits spinning sometimes, mostly when washing towels or mostly on a large load (sometimes a small load). Then it will work fine for a while. Nothing feels loose or hanging the agitator up. What is going on?
  • 619 Answers
May have a basket drive going bad. Not a bad job but can be tedious to get to.
Posted on Jan 31, 2010
Testimonial: "Thank you for the info. I will look up info for this. Is intermittent."
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Washer stopped agitating and spinning
the most common problem after a large load is the motor coupling has broke. it is what connects the motor to the transmission. it is not hard to replace if you can get the cabinet off the unit. you have to take the control panel loose and "hinge" it back to get access to the clips that hold the cabinet on to the frame. once you remove the cabinet, then take off the pump clips, the motor clips and then the motor. that will allow you to get to the coupling and replace with a new one. sounds easy but its not for a first timer. good luck and hope you can find this of some help.
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Kenmore 80 series model no. 110.26842691
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal De
