Question about Ovens
Self-clean cycle not working
Hi, the self-clean cycle does not work on my Frigidaire electric oven (FEF350BADA). The latch engages, and the light turns on, but the elements do not get hot.
Thanks for your help!
  • kurkevan Jan 31, 2010
    Your answer seems to have gotten cut off...
    Turns out that I didn't realize that on this model it is necessary to set the timer in order for the self-clean to operate. All's well that ends well, I guess! Thanks so much for your quick help.
  • 1,531 Answers
The first problem may very well be your control board and or as they call it a clock timer.while the unit is in the cleaning mode you need to check the power from the control board to the elements, you may also have
Posted on Jan 31, 2010
  • seth adams Jan 31, 2010
    to check the main power to your range. i am going to assume that the heating and broiler elements are functioning properly.
    i hope this helps your problem like to here what happens and how things turn out.please rate this answer.
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire gas wall oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire free standing, electric, self cleaning oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Good Morning: The self cleaning mode engages, locks the oven on the bottom, but does not clean. On the top, the latch does not engage at all on the self cleaning mode. What to do?
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
SO
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Mar 27, 2009 | Viking DEDO205 Stainless Steel Electric...
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Ovens Logo
98 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
