Question about Whirlpool LSQ8000 Top Load Washer
Whirlpool lsr5132pqo que tipo de aceite lleva mi lavadora y si se puede cambiar
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Oct 01, 2010
Que aceite ponerle a mi virago 250 del 2007
Hola, An?nimo para este escenario tendr? que tener su / manual del usuario del servicio si no puede encontrar la primera y la mejor herramienta alguna vez compr? para su Yamaha, la desesperaci?n no, por apenas $ 0 Usted puede descargar otro. Para obtener m?s informaci?n acerca de su problema y descargas valiosas "libre" que va a necesitar por favor haga clic en los siguientes enlaces. Buena suerte y que tenga un buen dia.
ViragoTechForum com
Yamaha Virago XV250 Oil Change Info
Yamaha VIRAGO XV250S Owner Manual
OEM parts for Yamaha
Yamaha XV250G Supplementary Service Manual
Jun 22, 2014 | Yamaha Xv 250 Virago S Motorcycles
Toyota tundra 2001
posiblemente no tiene suficiente aceite (no se que tipo de aceite),o puede ser que si las valvulas son hydraulic valves,necesitan llenarse de aceite para amortiguar el golpe cuando el motor esta corriendo.
Dec 29, 2013 | Cars & Trucks
Aceite
usted debe de consultar con su fabricante or mecanico. Debido a desgaste etc. or puede preguntar en una gasolinera que tipo de aceite puede usar. or vea su manual de instrucciones normalmente aparece el aceite recomendado
En mi pais las normas son diferentes, en USA SAE 40?, tambien las normas son diferentes.
God bless you
Jun 11, 2013 | 1999 Mercury Cougar
Hola buena tarde tengo una voyaguer 1994 la cual al parecer esta falladno la bomba de aceite, ya que al arrancarla la presionde aceite llega a 6 kg y al calentarse baja a menos de 3 kg, ademas que empiezan...
Asugurate de usar el aceite correcto segun el libro del vehiculo, aceite muy denso no circula bien por el interior del motor. Si sigue con baja presion de aceite podria ser la bomba. sammyc47
Feb 28, 2011 | 1994 Plymouth Grand Voyager
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Feb 06, 2011 | Whirlpool Dryers
Me prende luz de aceite toyota previa 1992 ...cambie el aceite...sigue igual...la bomba esta buena ya la revise...que puede ser?
Esa luz no se apaga por la precion de aceite yo tengo una previa 93 y la lleve con el mecanico a hacerle todos sus servicios y confiado que ya le havia echo todos los servicios me la lleve a un viaje y la fundi asta que le hice su over holl me dijo el mecanico que en la aceitera adentro lleva un filtro y que se avia tapado por un golpe en la aceitera checate si no tiene golpe la aceitera y si si ai que darle unos golpes para enderezarla y despues veras que todo bien si lo haces te ahorraras un buen billete
Nov 30, 2010 | 1992 Toyota Previa
Que marca y tipo de aceite se debe cambiar al motor que lleva la toyota previa 1991 y que cantidad lleva
hola, porque el toyota previa 91, tiene un tanque enfrente que al parecer es para el aceite de motor. pero bajo el aciento tiene otro que tambien indica aceite de motor. nadie me despeja esa duda y el tanque esta seco, pero el nivel de aceite de abajo me marca correcto. que hago? ayudenmeeee!
Oct 06, 2010 | 1992 Toyota Previa
Cuantos litros de aceite y que tipo de aceite lleva una jeep patriot 2008 4 cilindros gasolina y donde se encuentra su filtro de aceite y gasolina
hola que tal el filtro de gasolina lo traen arriba de una tolva que se encuentra exactamente por las ruedas delanteras ( abajo del motor) quitas esa tolva y es de lo mas facil cambiar el filtro y el aceite,, el de gasolina si esta un poco mas complicado pues esta dentro del tanque. lleva aceite del que quieras un 20w50 estaria bien depende de que kilometraje lleve pero mejor ponle un sintentico...
Sep 18, 2010 | 2008 Jeep Patriot
MI CADILLAC CATERA 98 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE Y EL CARRO CEMECALIENTA Y SE APAGA QUE DEBO DE ACE CAMBIA EL MOTO O Q
El problema está en el enfriador de aceite, que va instalado el el bloque del motor, justo en medio de las cabezas.
Cambiando el enfriador de aceite se resulve el problema. El # de parte es 93176626 y lo puedes comprar en www.rockauto.com el precio es de USD 235
Feb 18, 2010 | 1998 Cadillac Catera
Whirlpool LSQ8000 Top Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
