Question about Alera Technologies Wire Kit (ALR240122) Burner
I set up the wires for ss-ws502 and attached it to yamaha rx-v392 receiver subwoofer output but didn't work
How to hook up subwoofer for yamaha RX-496 2channels receiver
You need to connect the subwoofer to your receiver using the speaker wire connections on the rear of the receiver. Take the speaker input from the subwoofer to the A or B speaker terminals on the rear of the AV receiver. Then take the speaker outputs from the sub and connect to the main speaker terminals. Really you need to buy a receiver with a sub out to do it properly. Sell this one and buy another.
Mar 02, 2017 | Yamaha Audio Players & Recorders
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
Connection of a subwoofer to yamaha rx v480 receiver
Get an output from the receiver pass it through a crossover and you will get a low frequency signal , plug in into the sub..there you go.
Feb 09, 2014 | Yamaha Audio Players & Recorders
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
Computers & Internet Logo
91 people viewed this question
Top Alera Technologies Computers & Internet Experts
David Payne
David Payne
Are you an Alera Technologies Computer and Internet Expert? Answer questions, earn points and help others
