Question about HP OfficeJet d145 InkJet Printer
Windows 7: The system does not accept my old installation disc, does not mattter, because windows7 got the installation process alone. BUT now the problem: For printing double side (frontside and backside on the same paper), which was possible with my hp office jet d145 printer (I have the module on the backside) the system tells me: only the half will be printed, than take out the papers, turn around and the rest will be printed on the back side - BUT: I want to use the automatic printer-possibility and also: The way with turning around the paper does not work as well, because the printer does not stop after printing the even pages.... Thank you for answering! Best regards Gerald
    Sergeant:
  • HP Expert
  • 424 Answers
Posted on Feb 09, 2010
    President:
  • 1,126 Answers
You should be able to go to your printer, right click and select Properties, select Preferences, make sure the computer knows that the printer has 2>2 (duplexing) capabilities. See if you can't locate a place to select 2 to 2...
Posted on Jan 31, 2010
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
System disc
What type of system disc ?
operating system disc
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'.
Reboot the computer.
Hope this helps.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
Mar 06, 2014 | HP Compaq Presario SR1750NX PC Desktop
When I turn on the computer it says boot mgr is missing. I guess I totally messed up when I tried to do a full system recovery. The discs I have are from geek squad there is tow of them.
An operating system would have been nice ?
How to Create a Windows 7 System Repair Disc:
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 24, 2012 | eMachines ET1810-01 PC Desktop
I need to find a set up disc
What operating system set up disc are you referring to ?
bootrec.exe /fixmbr
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
System disks startup
bootrec.exe /fixmbr
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
or
bootrec.exe /fixmbr
hope this helps
Aug 09, 2012 | Computers & Internet
Installing windows7 os
When you build a new computer you will need to install an operating system (OS) to it; alternatively, if you are upgrading an old computer you may want to install a new OS. Installing Windows 7 is easier than installing any previous Windows operating system and can be done with just one DVD. This process can take up to up to an hour or more depending on the specifications of your computer.
Instructions
1. If you are upgrading and have a previous operating system installed, back up your important files to external media.
2. Turn your computer on and insert the Windows 7 disc.
3. Press any key when prompted to boot from the CD.
4. Click "Install Windows," "I accept the license terms" and then "Next."
5. Click "Custom." Select the empty partition you want to install Windows to. If you are upgrading, select your existing operating system, click "Format" and then click "OK." Then click "Next."
6. Follow the remaining onscreen settings to set your personal installation preferences. Click "Finish" at the end to finish the installation of Windows 7.
7. If you backed up files in step 1, copy them to the new folders such as "Documents," "Pictures" and "Movies" as appropriate.
Feb 22, 2011 | Computers & Internet
Iam using Windows7 ultimate.I have succesfully removed wga which appears at the bottem right corner using removeWat,but iam still getting the message that windows7 is not geninue.
If the windows 7 installation on your computer/laptop is not a genuine copy(purchased),and only been installed to your computer,it will not accept it as a genuine copy of Windows.You will need to purchase a new copy of Windows 7.You can also try calling Microsoft to confirm if it is in fact a legitimate,licensed copy.
HP OfficeJet d145 InkJet Printer Logo
91 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
