Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Compaq presario f700 has a power issue. The kid said it arced at the socket when he went to plug in the power supply. Now the battery won't charge and the unit will not run off ac. I have tried it with a known good ac adapter from my other laptop. I can put in a charged battery from my other f700 and it works fine.
    Genius:
  • 1,027 Answers
Yep, the power supply input to the laptop is gone - the external input shorted out. You may find that the Compaq repair charges almost equal a new one.
Posted on Jan 31, 2010
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
Compaq f700 won't power up
4 possibilities.
1 The Compaq f700 power supply is duff. How do you know it is actually working? Have you been able to test it on another system?
2 The charging circuits in the laptop have failed. Only a workshop can test this.
3 The Battery is dead. How do you know it is good if the system is not working?
4 There is a mechanical connection problem. Damaged lead/plug/socket etc. Examine and swap out to check.
Note that the system would not work if 1, 2 and 4 were the problem. (Since the system should still work of AC even without a battery).So a battery problem is the lowest probability.
Jan 04, 2013 | Compaq Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Jul 19, 2010 | HP Compaq Presario F500 F700 and G6000...
My compaq presario is not switching on.
Could be a number of things, related to the power supply. However if there are any lights on then it is likely to be a motherboard problem. Contact a local PC repair shop. I had a simiar problem and it was the on board video card. They should not charge to diagnose the problem. Mine cost £80 to fix at PCZone, Birchwood.
Feb 24, 2010 | HP Compaq Presario F500 F700 and G6000...
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Aug 26, 2009 | HP Compaq Presario F500 F700 and G6000...
Compact Presario F700...Not Charging`
your battery may have memory OR it is on the battery recall list because it is defective try the manufacturer's site and see if the battery is being recalled
Aug 12, 2009 | HP Compaq Presario F730US Notebook
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
291 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
