Question about Sewing Machines
I cannot get the bobbin case to seat into the chamber.....bought machine at a sale, could they have had the wrong case?
  • 255 Answers
Darn. This is so frustrating. Yes, they could have had the wrong bobbin case. The good news is that sm parts are fairly easy to get on line. Here are two of my favorite places:
http://www.sew4less.com/index.php
http://sewingpartsonline.com/
Good luck and let me know if this works, ok?
Robbie
Posted on Jan 31, 2010
Why the bobbin casing won't snap into place
Usually you need to hold the little latch open until the bobbin case is seated in the machine. Perhaps this video will help;
Singer Promise 1408 Get started
Mar 29, 2016 | Singer Promise 1408 Sewing/Quilting...
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
I need a manual and a bobbin case for a new home model 764
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
When I try to sew, the bobbin bangs around, like it doesn't fit.
Is it the bobbin or the bobbin case that is banging around? If I don't seat my bobbin case properly, it rattles and eventually falls out. Your bobbin case may be damaged, in which case, the bobbin is not going to fit properly. I dropped and stepped on my bobbin case once and the machine had the same symptoms. Then there's the obvious answer, a wrong size bobbin got mixed up with your bobbins. I've had that happen when I've taken a class with others. We all share tools and sometimes the right ones don't get back to their proper owner.
Nov 28, 2010 | Brother XL-2600I
The bobbin on my machine isn't working properly; the top thread doesn't complete a full rotation and the thread keeps breaking. I can't get past a few stitches without creating a jam. I have tried taking...
have you taken the bobbin case out and cleaned it. Its a simple process if you look directly at where the bobbin goes in you will see two latches one on either side of the bobbin case, release those and clean this area and oil it, reassemble and then reload. bobbin thread could be old or if the bobbin was wound on a different machine the tension could be wrong for this machine. when reassembling bobbin case make sure that all parts are seated corectly, also sometimes the actual case that holds the bobbin may need to be replaced, if its an older machine it could be worn.
Oct 29, 2010 | Singer 2250 Tradition
Sewing Machine (brother XL 3200) When I attempt to thread the machine I get to the part that I want to catch the top thread that goes through the needle with the thread that is in the bobbin and usually...
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Jul 19, 2008 | Brother XL-3500
Necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
May 01, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
