Question about Panasonic SC-HT820V System
I would like to connect the amplifier and woofer to another set.The panasonic deck is broken.
I have a Panasonic SC-HT692 5 disc theater in a box with a broken subwoofer and everything else functioning. Sounds like there's a functioning system if we put out parts together.
Posted on Dec 24, 2010
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Nov 03, 2013 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
Can I hook up 2 single coil subs at a 2 ohm load on my sony xm-1252gtr?
If your sub woofers are SVC (single voice coil) 2 OHM each, then connecting one to each channel would make the amplifier run in 2OHM stereo Then again, if your sub woofers are 2OHM each, it would be better to connect both together in series and connect them to the BRIDGE specified speaker terminals of your amplifier making it run a 4OHM load into one channel. This will give you all the power the amp can give and still run stable. A 2OHM load into one channel will likely damage your amplifier. Do not forget to set the LPF (low pass filter)on if you are going to use the amplifier to run sub woofer/s. dreamsystems
Feb 07, 2011 | Sony XM-1252GTR Car Audio Amplifier
I have a 2002 corvette, the base does not work on the Bose system....what could the problem be.
You have 3 choices - 1. the speaker is blown, 2. the wiring is broken or disconnected, 3. No output from the amp.
If you have a VOM, an inexpensive one wil work fine, and can get the speaker connection, set the meter to 1K, hold one lead against one speaker post and tap the other post, if the woofer cone moves it's not the problem. Connect the wires back to the speaker posts and then disconnect them from the amp. Hold one probe against one wire and tap the other - if the woofer makes a sound then woofer and wires are good - take the amp to the shop or buy a new one.
Jul 05, 2009 | Car Audio & Video
Power to technics rs-t24 dual deck
I own a RS-T24 as well and stumbled upon this thread while searching for this exact same solution. The RS-T24 generates no power on its own. It gets its power from, in my case, the SU-V75 amplifier. I still have a working SU-V75 and got the following readings out of the plug-in for the RS-T24 on the amp:
Left = pin 1 - (white wire)
Middle = pin 2
Right = pin 3
1-2 = 11.5 vac
1-3 = 23.0 vac
2-3 = 11.5 vac
Jan 30, 2009 | Technics RS-TR272 Single Cassette Deck
Sony 1200 watt amp
What kind of deck to you have? Sometimes there's a setting for the subwoofer output that has to be turned on. How is the deck hooked up to the amp? Be sure of the normal things: -Make sure the sub is connected in side it's box -Make sure the RCA cables didn't come off the deck -Check every connection! Let me know and be sure to leave feedback or I don't get paid.
Oct 03, 2007 | Sony XM-2002GTR Car Audio Amplifier
Panasonic SC-HT820V System Logo
102 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
