Question about Hotpoint Dryers
Hotpoint tcm570 makes odd noise in reverse only
Neil_lewis08 - did you get the problem with the TCM570 sokved - having same problem with same dryer - only in reverse.
thanks
dave
Posted on Mar 18, 2010
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Hotpoint condensor dryer model tcm570 only blowing
CHECK UR THERMISTOR OR CYCLING THERMOSTAT, UR OTHER THERMOSTATS AND THE HEATING ELEMENT WITH A MULTIMETER
Sep 25, 2014 | Dryers
Hotpoint tcm570
Try replacing the capacitor, you can pick them up cheap enough and only cost 5-6 online, just ensure you replace like for like do not change the rating of the capacitor
Apr 05, 2014 | Washing Machines
1991 geo prism makes grinding noise when i put it in reverse
do to this form format , and odd first post box.
are you scott and saying it is an A/T
and Automatic? transmission>?
if yes, call AAMCO.
Apr 14, 2013 | 1991 Geo Storm
How to remove the covers from tcm570 to relpace drive belt
hi ile try to help dont know that model here goes behind kick plate you should hav about 4 screws open door there should be anouther 4 if so 1st step is to take top off to take control panel off mark were all wires go you will have a screw either side connected to front aswell
Jan 05, 2013 | Hotpoint Dryers
Hotpoint TCM570 working but not drying clothes? Is there a reset button or do i need a new heating element?
it maybe the thermal fuse, but here is a website for probable causes, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Apr 23, 2011 | Dryers
My hotpoint aquarius TCM570 dryer is only cold air is there anything i can check before calling someone out?
Your heater is protected with a thermal cut out.
With a multimeter you need to check that the thermal cut out has gone open circuit.
You also need to to check the heater itself.
Remove the rear panel of the dryer.
Behind there is the cowling that covers the heater. Once you take that off it will reveal the heater assembly of which you will see two thermal devices mounted on the top. One is a thermal fuse the other is the auto reset.
You need to check both of these.
If both thermostats and the heater check out ok then try an identify the thermostat located in the door way. Check this with your multimeter for open circuit.
Dec 01, 2010 | Hotpoint Dryers
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Dryers Logo
438 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
