Question about Geha Primo 2600 Shredder
Order main drive gear for geha paper shredder
Geha 260 paper shredder
i need to know the price and availability of the main larger plastic drive gear for a geha 260 cf (top secret) paper shredder.
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Before I recycle the metal from my DS-1 Fellowes shredder (small driven gear stripped) does anyone need any other parts? Two larger gears are good. Norm
I'm desperately looking for the small nylon gear (see attached photo) of the DS-1.
As I live in Brussels, Belgium I'm also curious to know where you have found the gear outside US and at which price.
Thanks,
Dirk.
before-recycle-metal-from-ds-1-fellowes#solution-section-ew2ec1vog3kw5zx5dcajxfma-4-3.jpg
Jan 27, 2015 | Fellowes Office Equipment & Supplies
Geha Primo 1500
every thing is serviceable !
problem here should be is a replacement part available to fix it.
you check with the maker to see if parts are available.
Aug 11, 2014 | Geha Primo 1500 Shredder
The fiber gear driven by thde motor is stripped.
Nearly impossible to find at a price that will make it worth it unless your planning to buy them in bulk from a distributor and do this type of repair often.
May 07, 2010 | Geha Primo 2700 (Cross-Cut) Shredder
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
May 26, 2009 | Office Equipment & Supplies
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Parts available from broken SX102M
is this gear still available, if not are the bushings that it goes into still available. if so please contact me at iseicon@aol.com
Jun 21, 2008 | Cross Infoguard Shredder SX102M
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Geha Primo 2600 Shredder Logo
624 people viewed this question
Top Geha Primo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Geha Primo Office Equipment and Supply Expert? Answer questions, earn points and help others
