Question about Electrolux EW1200i Front Load Washer / Dryer
Will not spin, water being pumped out and no blockage
  • Electrolux Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewill not spin, water being pumped out and no - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 26, 2010
Code 37 on iwl12 f&p washer
You need to blow air down the clear pressure tube to remove any blockages that prevent the water level from changing.
Jan 25, 2012 | Fisher Washing Machines
Hi we have a hotpoint aquarius extar 1300 spin wma46 that wont spin at all even with no clothes in ?
hello is it pumping out water if not check the pump for blockages it has to pump water out first then it should go into spin cycle. if does pump water out and still not spinning then there could be a problem with the module board this control the motor speeds hope it helps
regards
shaun
Mar 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Washing fine but is only spinning slowly and when finshed washing is still wet and some water still in barrel it has been spinning very noisely for weeks but decided to turn the radio up so i couldn't hear...
Water left in the drum could indicate a blockage in the outlet pipes or pump, could also be a faulty pump but this is to be checked after looking for a blockage. May be spinning slower due to the water that is being left in the drum as it will create extra weight against the motor.
If just a blockage once cleared it should spin back to life.
Feb 24, 2010 | Hotpoint First Edition FEW12 Front Load...
Water not spinning out. clothes still wet when finished spinning.
check that you have water going down the machine drain pipe when the machine would normally be draining, if not could be a faulty water pump or a water pump blockage the machine is spinning whilst still full of water I am suprised you can open the door after the wash has completed
Jan 16, 2010 | Washing Machines
Washer won't spin or drain water
Sounds like a blocked pump (turn on, advance thru to spin, press start- do you hear a humming noise? if yes, pump is blocked).
Disconnect from power.
Manually bucket as muh water out of machine as you can. Then lean machine over so you can access underneath machine.
Drain pump located right front- it has a kind of fan blade at the bottom. This fan blade should turn very easily- if not, there is a blockage.
-To remove pump, remove plug wires from pump (1 plug with 2 wires, 1 plug with 1 earth wire). Then there is a white plastic tag located at the top of pump-pull this gently towards you, and turn whole pump assy anti-clockwise. Pump assy will drop out easily- do not force (note- water will come out too- put down some towels!!) Remove any blockage from pump, and reach fingers into bowl where pump has come from to check for any blockages. If OK, reassemble and retry.
Aug 08, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water does not drain and cyl does not stop
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Jan 28, 2009 | Maytag Dependable Care LAT9706
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
319 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
