Question about Kenmore 24032\24036 Top Load Washer
Hi, after the tub filled the lid slipped and slammed shut now the tub is full of water but the washer is completely dead. could find no fuse in the system. any help would be appreciated! Jason
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
You have broken your lid switch. it is in the spin, drain circuit. replace.
Posted on Jan 31, 2010
Testimonial: "Thanks for your help!!"
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
Whirlpool utlra care II clothes washer shuts off when filling - push knob in and pull out it starts again - once full it completes remaings cycles
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 17, 2010 | Whirlpool Washing Machines
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
STOPS IN MIDDLE OF CYCLE, HAVE TO OPEN LID AND SLAM IT TO COMPLETE CYCLE. ALSO AGITATOR DOESN'T SPIN WHEN WATER IS IN TUB.
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: You do not have to drain the washer to complete this repair. Once the lid switch is adjusted or replaced, the water will drain. This will save you time in having to bail water.
PS Slamming the lid switch is not recommended. This will actually break the switch or bow the lid and make the problem worse over time.
Jul 06, 2009 | Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Water fill stops
Your lid switch is probably damaged or loose. Examine the lid switch on the right-hand side of the washer tub opening. There are two screws that hold the switch in place. Check to see if they are loose. In addtion, the lid should have a small plunger that depresses the switch when the lid is closed. Make sure it is intact and not broken. If the switch is tight and the plunger is intact, the switch has probably been damaged and needs to be replaced. If you have the type of washer that has no visible plunger and/or switch, the lid switch is locate in the rear on the left hand side and has a small arm attached to the lid that activates a contact when closed. Often this arm can get bent and will not engage the lid switch contacts. A simple adjustment (sometimes) can correct this. I've seen a lot of these switches where the casing on the switch separates and the contacts will not close. Slamming a washer lid is highly NOT recommended just for this very reason. The switch is an easy replacement and costs roughly $35. If youy post back with your model number I can research to find a part number for you. I will also give you step-by-step instructions on how to replace it. I hope this helps.
Oct 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24032\24036 Top Load Washer Logo
95 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
