Question about Nintendo Wii Console
Cannot connect to the internet
Error code51330
    Genius:
  • 1,234 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
My internet keeps giving me a internet connection error
Step 1:
You might have some unwanted browser interference
Internet connection and network errors can be frustrating and confusing to a casual computer user. However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues. This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems." A window will appear, displaying the start page of the diagnostics tool. Follow the instructions to determine the cause of the connection error. The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing. Close all programs and restart the computer. If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again. Call your Internet service provider's technical support phone number if you cannot resolve the error with the diagnostics tool. The Internet Explorer diagnostics tool cannot repair or reset malfunctioning or failing hardware like modems and routers.
windowsxp using networking expert russel diagnostics mspx http://www.microsoft.com/windowsxp/using/networking/expert/russel_diagnostics.mspx Support for Windows Internet Explorer 6, 7, 8, and 9 http://support.microsoft.com/ph/13418 - tab0
Mar 13, 2013 | Computers & Internet
I try to connect to the internet and get error code51330
If this is for a Wii system then It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
Sep 08, 2011 | Computers & Internet
Can't connect WII to netflix. Ger error code51330
This error usually indicates that the WEP key you set on your Wii is not the correct one to gain access to your router.
When you setup a router for wireless internet, you usually set a WEP key. This is basically a security key(password) that you set so any device that wants to use your internet, has to enter correctly.
If you know your router security key, go into your Wii network settings and make sure it is entered correctly. I wrote a article on how to configure your Wii for internet. Click here to read it.
If you do not know the security key of your router, then read my other article by clicking here. This article will go over how to find the router security key.
Let me know if you have any questions.
Regards,
G33k
Jun 14, 2011 | Nintendo Wii Console
Will not connect error code51330
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=lang
Jan 23, 2011 | Nintendo Wii Console
I have the wii and i have an error code51330
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
    1. Go to our Wireless Router lookup page.
  4. Try a "Manual Setup" with the Wii console, using your network's IP configuration settings. To access these settings:
For any further clarification, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 04, 2010 | Computers & Internet
Error code51330 trying to set up wi for internet
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Aug 04, 2010 | Nintendo Wii Console
Internet connection
This error is related to the wireless internet connection. You can either restart the router and the modem to refresh the internet connection. Or manually set the IP address settings of your Wii so that it will be able to connect to the internet.
Feb 15, 2010 | Nintendo Wii Console
Psp error
Connection PSP to internet
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 12, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
