Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bosch Exxcel (SGS47E02, I think) no longer heating water
Our Bosch Exxcel Dishwasher has stopped producing hot water. It's just over 2 years old (if that) and has been trouble free up until now.
At the same time it stopped producing hot water, it also developed and issue where the wash cycle will run through it's setting OK (regardless of program selected) but wouldn't finish i.e it would get to the last minute and stay on (keep washing) indefinitely... until I either reset the program or, turned the machine off.
As this machine only takes a feed from the cold mains supply, I can only assume it's either software related (something's gone wrong with its programming) or, whatever hardware it uses to heat the water (like an element, or something) has packed up.
Is there a simple reset type function I can do to get this working again or, am I looking at paying to get a Bosch engineer in to replace something in the machine?
Any help would be greatly appreciated.
Many thanks,
Mark
  • 3,741 Answers
You will have to check the the temp sensor. if the temp sensor is ok.then the control panel needs to be checked.If the control panel does not see a temp sensor, it never turns he heater on. There is a thermostat on top of the water heater. Is it being energized?
Turn off power at breaker and test the heater for continuity.
If it's open, the heater is bad.
if it shows continuity, you have to trace the control voltage.
Taking apart a Bosch unit is TOUGH for gaining access to the heating element. Its a ral bear so I would advise getting a well Bosch versed guy in to do this replacement. Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 31, 2010
My bosch dishwasher will not take in water
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My dishwasher dont dry
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 18, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Why is my dishwasher not drying it does all the rest like washing rinsing but not drying
The heating element is bad and not making heat...
you will not notice it much on the wash but will on the drying..
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
May 06, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
No hot water
start by checking your water going to unit make sure it is hot , two check your water valve with ohms meter
Mar 01, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Not draining water and not cleaning all, pipes ok is machine just old bosch exxcel dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
e
Dec 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
280 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
