Havin trouble finding driver downloads for the motherboard need manual
98,856 people viewed this problem
This solution has been voted best by the Fixya Commnunity
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom (mailanmeyer@gmail.com)
Here's the manual for the Foxconn N15235 that has all the info for the board !!
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=P4M800P7MB-RS2H&TypeID=en-us0000001
Please I neeed driver motherboard foxconn N15235 very soon, help me?
Try this,
[URL=http://www.mxupload.com/i3es2qvlh8rg/VGA-n15235.zip.html]VGA-n15235.zip - 20.3 MB[/URL]
[URL=http://www.mxupload.com/1vjv9vjz0x4w/Lan-n15235.zip.html]Lan-n15235.zip - 4.35 MB[/URL]
What mainboard is suport mainboard Foxon n25235
I believe the motherboard you are looking for is the 945G7MC-KS2HV which can be found here (http://www.foxconnchannel.com/product/motherboards/detail_overview.aspx?id=en-us0000294)
Thank you
The foxconn board identifcation number is located between the processor holder and the ram stick module bay.
for instance the one i am on currently shows a white sticker and a ****-* (which is your mobo number and the word series beside that number.)
hopefully that will help and i can also refer you to the site in which foxconn has their site.
http://www.foxconnsupport.com
hope this helps you.
DARK
Sound drive
In the Packard Bell iMedia X9645
the motherboard is FOXCONN PT8907MB-2.0-8ERS2H
BUT NOT FOUNDED IN THE FOXCONN SUPPORT WEB PAGE
Hello Sir,
First U install the software called Belarc Advisor.
It will detect what type of motherboard and the exact motherboard
driver number will be found in this software(small software as html
view). U will be find at this site.
http://www.belarc.com/free_download.html
The Belarc Advisor builds a detailed profile of your installed software and hardware, missing Microsoft hotfixes, anti-virus status etc.....
After
Finishing installtion the Belarc advisor check out the Motherboard
number and search in the website for download. Check out for this site
for motherboard driver download....
Thanks
Don't forget to comment
Good Luck
Cheers!!!!!!!!!!!!!!!
Beware there are several motherboard types with this number N15235 clearly printed, and a tiny label with the actual motherboard type P4M800P7MB-RS2 in my case.
My mbd had two barcoded labels next to the 'Foxconn' brand, the motherboard name was the SECOND item on the slightly larger top label of the two.
Can this be deliberate attempt to make it difficult to find the type ?
Bloody stupid nonsense !
i hav loaded vista premium in another drivers havin xp too...my problem is tht when i updated my vista ...sound of my xp...
I am having trouble finding the PCI Driver for this motherboard. Can someone advise where I can download this please. I...
i also need the drivers. can i download these to a flash drive?
i do not have driver for my pc. the driver is intel celeron 331 865G-MB. could help me with this?
Guest plugged off all the power sw pins and don't know where they are supposed to go now. the lights are on but the fans and the system won't start
Apr 29, 2009
Guest i have a foxcon p4m8007mb-rs2h
i was running a celeron 1.6 cpu and now i have upgraded to a intel 2.6 and m y pc wont work is the board able to run with the 2.6 cpu ???
Apr 06, 2009
blonskib please can someone tell me where the hdd led , ps led and other pins are suppose to go. I need the pin order....which pin goes first. I removed them and was thinking the order was on the board- MY BAD!!! Somebody please help. this is for the foxconn n15235 motherboard (P4M800P7MB-RS2H)
Jan 25, 2009
Guest yes
Jan 21, 2009
dimakis Hello ! I just perchased a used Intel D845GRG Motherboard and I have problems with the power sw, reset, Power LED and HDD LED cables! I connect them exactly as the manufacturer describes, but the motherboard does not turn on! (The Motherboard LED greens on normally!) Also the first time I connected the cables just like my old motherboard and it turned on, but the power-reset key where not working! Do you know anything about this??
Thanks a lot!!!!
Jan 12, 2009
jaadiea NO MANUAL CAME WITH THIS USED MB. MB NODESCRIPED ON WHERE THE PLUGS GO FOR POWER SW, POWER LED, RESET SW, H.D.D. LED, BLACK UNMARKED LED
Dec 04, 2008
richardbecke need drivers for an15235
Nov 08, 2008
Guest I need manual to to trouble shoot problem with N15235 mobo
Oct 20, 2008
Guest faxconn n15235
Mar 13, 2008
