Question about Frigidaire Ovens
REPROGRAM OVEN - Frigidaire Ovens
  • monserat_81 Jan 31, 2010
    AFTER CLEARING,THE FAULT F3 AND DOOR LOCKED ,REPROGRAM OVEN
    F3 IS DISPLAYED,LOCKED OVEN DOOR,REPROGRAM OVEN
  • 3,741 Answers
Click on the link directly http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318200191.pdf check out the user manual. F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control----------
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try.... 1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door.
2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
if still the same problem continues then ------
you probably have a bad circuitry problem. I would start with checking the door lock switch. This switch reports to the EOC and if bad, will give a faulty reading, thereby the EOC thinks that the door is locked or vice versa. It is basically a "protection" mode that it goes into for safety reasons. On Frigidaire models, it is usually located on the right hand side, and the right hand door hinge activates it. You may need to remove the right panel to get to it to test. If you are proficient with and ohm meter and understand the internal workings of an oven, then you can more than likely do this repair. If not, I would call a reputable service person to properly diagnose your problem and get a quote for repair.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 31, 2010
    Brigadier General:
  • 3,513 Answers
It would have been great help if you could have passed down the error code where its stuck now. Press "cancel" to clear it. If the code doesn't clear, you have some bad circuitry that needs testing, possibly the door lock switches. Please find the error codes and their remedies.
Thanks for contacting fixya.com
  • 1 more comment
  • Aparajita Batabyal
    Aparajita Batabyal Jan 31, 2010
    F1
    Circuit board defective
    Replace control board
    F2
    1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked
    1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
    2. Check 8-pin connector. Check and replace oven temperature sensor if necessary
    F3
    F3
    F4
    Oven temperature sensor is shorted (below 500 ohms)
    Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control
    F5
    Internal watchdog circuit has detected a failure
    Defective EOC (Electronic Oven Control)
    F6
    Shorted buttons
    Check push buttons and dome switches on control
    F8
    Logic interrupted (lock motor switch sequence)
    Check door lock switches and wiring
Error f19
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
May 04, 2014 | LG LWD3081ST Electric Double Oven
Oven just beeps when i turn it on
Hit stop clear then reprogram oven If that won't work unplug for a short time plug back in and see if this works. It found a fault code in the oven control and if you can't reset it. You will have to order a new one. Go to managemylife.com if you need to download manual
Dec 09, 2011 | Kenmore Ovens
Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
Oven beeps and shows F7.
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
Touch pad on double oven shows code F7
Electronic control has detected a fault condition. Press STOP to clear the display and stop the
beeping. Reprogram the oven. If a fault reoccurs, record the fault number.
Jul 07, 2009 | Ovens
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Reprogramming the oven
Link to the timer guide for the oven in english. Should have everything there:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200181.pdf
Aug 23, 2008 | Frigidaire GLEB27S7A Electric Single Oven
My oven is beeping!
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
Jan 26, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
