Question about Honeywell Programmable Thermostat Heater
Steam Cast iron raditor makes a loud popping or banging sound.
I have onr cast iron radiator that makes a loud popping or bang sound when heating and coolling. I removed and drained the radiator and the sound is still there. Latly I replaced the radiator with another radiator and the sound ig gone. What is wrong with the original cast iron radiator and how do I fix it?
  • 1,420 Answers
Some cracking and pinging is normal due to the thermal expansion of the metal. If some make more noise than others, it could be an indication of a plugged or restricted steam vent (the chrome gadget on the side of the radiator) or that the return line at the boiler needs draining or that there is too much water in the supply lines. A good flushing of the supply and return lines will help. Check your water level after flushing. I would replace the original steam vent on the suspect radiator and see if that helps, it could be over heating.
Posted on Jan 31, 2010
Why will it not heat when using cast iron cook wear
never knew coffee pots that used cast iron cook ware .
Feb 04, 2016 | Coffee Makers & Espresso Machines
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
How to disassemble cast iron radiator
Here's how to they're assembled - disassembly is the reverse:
http://www.mhsradiators.com/assets/19.asset
You'll need Adobe Reader to view the PDF file pointed to by this link.
The Radiator Spud Wrench below may prove useful, but it's a plumbing specialty tool that a licensed master plumber would have.
Nov 27, 2011 | Cars & Trucks
I have steam heat when i turn my heat on i get black dust all over my homeon child toys
Steam heat-- I can appreciate that-- I have done Maintenance work on Steam systems for years-
Most of my systems have big cast iron radiators, and a valve on one end, and a steam trap on the other end of the radiator.
The radiator has to be painted with a silver paint-- or it will rust easily--
Tell me about your radiator, and is there rust?
Is there any leakage at the radiator valve-- like at the stem packing?
Sometimes the water that leaks out of the packing can be black-- (It is iron oxide, too..)
Do any of these comments help your trouble shooting?
Tell me more, so I might be able to help you further.
Mack B
Jan 17, 2011 | Heating & Cooling
Radiators only working on the top third? please can anyone help! it is a central heating system
If old cast iron units, they are probably filling with rust and debris not allowing the water or steam to get to the lower sections. You will need to have them cleaned. Not an easy fix. They will need to be removed and either power washed or acid dipped. Make sure the valves are open fully to allow as much flow through them as possible.
Jan 06, 2010 | Heating & Cooling
We had a powerflush yesterday,today we have no hot water when we put water on its making alot of noise banging etc? sounds like air in the tank or pipes?
Sounds like you have a boiler type heating system and when it was flushed air got in the system. If you don't have automatic air bleeders in the system then you will have to bleed the air out manually. On the radiators depending on the style there should be a nut with a screw in the middle(on most cast iron radiators) or a elbow with a bleeder (on most radiant baseboard slant fin style)
Dec 11, 2009 | Desa International CBN30T Central Heating...
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
Heating & Cooling Logo
483 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
