Question about Garmin GPSMAP 545s GPS Receiver
Garmin 545s : The unit powers up, the keys are illuninated, however, the display creen is blank (black no image). The unit beeps when I push the + and - keys and menue keys, but no display?
  • 1 more comment
  • gerstein2 Jan 31, 2010
    Thank you for your software upgrade advice. Will the Garmin automaticly install the upgrade when it is turned on and the SD card is in place? I can not give it any commands at this time to have it download the upgrade unless this happens upon startup by itself . Ordinarily, I used to have to press a command at a screen prompt to simply get the garmin to intiate.
    Anouther question is if this will indeed update itself automaticly upon powering the unit on, will my stored boat tracks in the garmin hard memory be wiped out. I do not want to loose this information.
    Thanks,
    Ed
  • gerstein2 Feb 03, 2010
    Your solution was no starter. The garmin display is blank and I can not get it to upload the program without going through the display commnads. I asked you about this before going through the process. You did not rspond so I asumed that it would automaticly update with the SD card in place without me having to follow some screen prompts on the garmin. THE SCREEN IS NOT ILLUMINATING >>>>>NO IMAGE TO WORK WITH. HOW AM I SUPPOSED PREFORM AN UPDATE WITHOUT A WORKING SCREEN?
    IF THE SCREEN HAS BEEN JOLSED LOOSE HOW DO I REPAIR OR TIGHTEN? IT COSTS A MINI OF $165 to have Garmin look at it.
    SO far none of these solutions are even executible, The screen is blank puting in the SD card with the software update does nothing as the unit does not automaticly upgrade upon powering up. You need to see a menu screen to even proceed. How do I rpair this unit so the screen comes back on.....last chance before I cancel this service.
  • 17,970 Answers
Somone GPS, initially opens with a blank screen, because the geographic extent desired is unknown. To start, either connect a Garmin Receiver to the serial port and use GPS, Read From GPS, or View, Enter Coordinates. A good way to find starting coordinates for planning a hike or bike or ski trip is to use the USGS Geographic Names Information System search form United States and Territories.
Posted on Feb 03, 2010
  • 2,069 Answers
Please run an update on your unit first using Garmin web updater first. If Display problem continues, consider servicing unit because the display could have gone loose especially if in any case it fell down or got water damage etc.
Please visit HERE for update.
Regards
Posted on Feb 01, 2010
  • Muzahura Frank Feb 01, 2010
    As indicated on their website, you only have to download the updater to your computer, install it and thereafter, connect your Garmin to the pc. just follow the on screen instructions. During updating process, your data is reserved. so long as you do an update, your existing data will stay on device.
    Regards
    specifically for your unit HERE
    President:
  • 2,501 Answers
If the unit is new and not a fault that has just developed, there could be a very simple answer.
Have you inserted the map SD card?
  • 2,335 Answers
I recommend upgrading the system software of your Garmin 545s. There may not be physical damage to your unit, and it may be completely revitalized by replacing the GPSMAP software with the latest version 5.30 (as of January 7, 2010).
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
I hope that helps.
Posted on Jan 31, 2010
  • Paul Sager
    Paul Sager Jan 31, 2010
    You can find these instructions again easily by following this link to the Fixya Tips section.
My garmin 545s does not turn on
My Garmin 545s would not power up. I took the unit to West Marine, where they had the correct cable to hook it up and test it. The unit immediately powered up and I purchased a $22 cable and installed it. Easiest test and fix I could come up with. Really cheap fix.
Sep 25, 2013 | Garmin GPSMAP 545s GPS Receiver
Tip
How to Download your Garmin GPSMAP 545 / 545s Users Guide
Have you lost your User's Manual for your Garmin GPSMAP 545 or 545s?
Would you like a digital copy for easy searching of terms and quick reference?
The GPSMAP 545 owner's manual is available from Garmin here.
I hope that helps.
on Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
Tip
How to Upgrade and Fix your Garmin GPSMAP 545s System Software
Does your Garmin GPSMAP 545s freeze up?
Is the screen stuck, or do you loose satellite coverage?
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
Garmin 545s lost gps signal/reads gps error on satilitte page
Lost Satellite Reception - the unit has lost satellite signals. Check
antenna connections or try moving to a location with a clear view of
the sky.
Jan 11, 2012 | Garmin GPSMAP 545s GPS Receiver
My garmin 545 wont turn on. it was working fine and I switched batteries. now it wont turn on
Follow these directions to replace the system software of your Garmin GPSMAP 545s. This should fix it up. It is not uncommon for firmware to become corrupt when switching batteries on some devices.
I hope that helps.
Nov 26, 2009 | Garmin GPSMAP 545s GPS Receiver
I lose satellite coverage on a fairly regular basis. The 545s is mounted in the open.I have only used it twice.
Please review this page for instructions on how to upgrade your units system software. There have been many upgrades for this unit, increasing its accuracy and dependability.
I hope that helps.
Aug 06, 2009 | Garmin GPSMAP 545s GPS Receiver
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
When I turn my Garmin Forerunner 201 on, the background lights up but there is no display, it is just blank. Pushing the buttons produces a beep sound but still no display. Is there a something I can do,...
Hold the reset lap button along with the power button for three seconds and let go of them at the same time. It took a few tries but it eventually worked.
Apr 18, 2008 | Garmin GPS
Garmin GPSMAP 545s GPS Receiver Logo
627 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
