Question about GE Profile Spacemaker Over-the-Range Microwave
I have a GE Profile microwave/convection oven JVM1790SK01 installed over our cooktop. The exhaust fan doesn't work. It turns on and you can feel it blowing outside, but it doesn't actually **** up anything from the cooktop. Help!
  • 4 more comments
  • lgayvert Jan 31, 2010
    Opening the window doesn't seem to help. There is just no pull. The steam or smoke just rises and rolls right up the front of the microwave instead of being pulled into the fan.
    I have a JVM 1790SK 01 microwave/convection oven installed over the cooktop. The exhaust is vented to the outside. When you turn the fan on you can hear it run and if you are outside you can feel it blow out the vent, but it does NOT pull any steam or smoke from the cooktop. It floats up and just rolls up the front. This was installed 1.5 years ago and has NEVER worked properly
    do you think the fan could be installed backwards?
  • lgayvert Feb 03, 2010
    Where would I find this "knock out panel"?
  • lgayvert Feb 12, 2010
    Thank you so much. I really appreciate all of your hlep.
  • lgayvert Mar 31, 2011
    Hi Woodchuck789,
    I responded a year ago. Since then, my hubby had someone come in (while I was out) and he made some 'adjustments' but did NOT unmount the unit at all. So, it still doesn't work---big surprise. I would just unmount it myself, but I am afraid I don't have the right tools and that I'll mess it up trying to put it back. I live in Maryland near Annapolis. Do you happen to know anyone in this area who is knowledgable, honest and not ridiculously expensive? Or should I contact GE directly? This is so frustrating!
  • 999 Answers
Remove the filters if installed and with the fan running, place a sheet of paper under the micro and see if it is drawn up to the micro. If yes then it is working and the filters are plugged. IF no, then it is likely the fan is in the wrong position and you will have to drop the unit to reposition the fan assembly.
Eric
Posted on Feb 01, 2010
  • 4,059 Answers
It's pulling air from somewhere since you feel it outside. I suspect an installation problem. It need to be inspected for an opening where the air is being pulled from. If it goes out the roof it could be in the attic.
Posted on Jan 31, 2010
  • 1 more comment
  • Charles T Nevin
    Charles T Nevin Feb 01, 2010
    If the fan were in backward or wired backward you would feel the air being blown from the air intake. Is the fan blade turning or slipping when the motor is running. You may can see it by taking the filter off.
    If you still feel the air blowing outside you'll have to find what air it's blowing. It's coming from somewhere but not from your oven top. You have a leak somewhere..
  • Charles T Nevin
    Another possible problem causing this is that vents can be vented outside or vented to recirculate through a charcoal filter. Make sure the knock out panel which allows the air to vent outside was removed. The oven may have to be removed to determine this.
  • Charles T Nevin
    Charles T Nevin Feb 03, 2010
    In this diagram it looks like where parts 52 and 53 goes is where the air should come out. It's on the top. So while you have it unmounted you can turn the fan on to see how the air goes and check out the duct work which takes the air away to the outside. http://www.appliancepartspros.com/partse...
  • 1,531 Answers
Is your unit vented to the outside of your home,if yes then for these units to properly work in the kitchen air it needs to have good air flow you should have a window in the kitchen area craked ope to allow new fresh ai to enter your home while it evacuates the air you are trying to vent to the outside.if there is no new air to replace the air you are moving out it will not work right.
if your unit is not vented to the outside then all the air you are trying to pull up from the ranges just gets blown back in the same room but you still ned to have a window cracked open in order to circulate the air movement.
  • seth adams Jan 31, 2010
    these fan are located in the center and rear of the microwave.they will not pull the steam up from the front burners of the stove,because they are to far forward of the suction action of the microwave.if there was something that could help direct the flow of steam to the fan it would **** up the air.
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Sep 07, 2012 | Microwave Ovens
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
I have installed 2 new light bulbs in my GE Profile SpacemakerXL Microwave Oven, Model JVM1660, and now I can't get them to work. These lights are used as Cooktop and Night Lights. I can't find any fuses...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Mar 04, 2009 | GE JVM1790 1000 Watts Convection /...
My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
How can I replace the interior light on ge profile microwave model# jvm1790sk01?
Take the vent off of the top of convection oven, there will be two screws, then inside center front, you will find a metal box open both ends the light bulb is in there. The light you will need is a holegen 120 Volt 20 Watt they can be found at home depot. Hope this helped you
Nov 04, 2008 | Microwave Ovens
GE Profile Spacemaker Over-the-Range Microwave Logo
195 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
