Question about Dryers
Hotpoint WD61 Loud buzzing while Tumble drys
Hotpoint WD61 8 years old. Tumble drys OK, but makes a very loud buzzing noise while it does it. What might be wrong?
Regards
Steve
  • steve249 Jan 31, 2010
    Thank you very much.
    That seems a very comprehensive reply.
    I suspect I will have to get an engineer in.
  • Dryers Master
  • 43,501 Answers
There are a few things that could cause that...
First, make sure that you do not have a loose electrical connection. Make sure that you remove ALL power to the dyer and check the connection at the power cord in the back, that everything is tight. If the connections are overheated and burnt you will need to replace them.
Next, make sure that there is nothing stuck in the blower/fan part of the dryer. It is possible for somethings to get through the lint screen and flapp against the blower wheel and cause a buzz. The dryer may have to be dissasembled quite a bit to get to the blower.
Finally it may be a symptom of the motor going bad. Usually if that is happening the motor will pull high amps. also. To check this turn your dryer on at a fan only or no heat setting and check the amp draw. Check the name plate rating on the motor to see if the current draw is hgiher than it should be.
Heatman101
Posted on Jan 31, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My Hotpoint vented tumble dryer Model number
tvm 570 bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Aug 28, 2014 | Dryers
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
My GE Harmony Dryer is making a LOUD noise during entire cycle
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
Out hotpoint dryer is 8 years old and juist
Sounds like the drum bearing or shaft is worn.
Remove rear panel of dryer, you should see the drum shaft, check for wear here.
Jan 17, 2010 | Hotpoint Dryers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud noise as drum turns,gets louder as speed increases.
There is no doubt that the drum bearings have failed from your description.
The normal procedure is to replace the whole drum and tub assy as a complete unit, this makes it a fairly straight forward repair, though relatively expensive.
To strip it down and replace worn bearings, is a very involved repair, and not one I would recommenend.
If the washer is less than 5 years old, then you can get it done under the Hotpoint 5 year part guarantee, but you would have to contact Hotpoint about this.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Dryers Logo
43 people viewed this question
Top Dryers Experts
