Question about LG WM-2277HW Front Load Washer
Light Stays on in the LG front loading washer
Why will my light not go off?
  • yadayada
    yadayada May 11, 2010
    what is the machine doing?
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
danromarris
  • 101 Answers
SOURCE: LG front load washer wobbles
You might have a broken shock. There are two shocks located inside the washer that support the drum during spin and agitation. They can break from over loading the machine. If you take the back off the washer you will be able to see the two shocks, one on each side. Check to see if they are broken, cracked, or even if they are not stiff anymore. It will be a good idea to just replace them as this is most likely the problem. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad that I could help.
Posted on Jan 22, 2009
SOURCE: LG WM2487H*M Drum light stays lit after each load is completed
I checked with a certified technician on this problem. Unfortunately the repair cost me $200. The main circuit board needed to be replaced, and the unit works as advertised now. It's actually easy to access the circuit board in the left rear of the washer, but it was a challenge to remove the 16 connections! If you aren't intimidated by this kind of repair, take your time and all will go well.
Posted on Feb 21, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 197 Answers
SOURCE: Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Posted on Sep 29, 2009
Drum light stays on but washer won't power on
look for a blown fuse in panel or a bad door switch
Jun 08, 2015 | LG SteamWasher WM2801H Front Load
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
LG WM3001HPA Washer interior light is on but will not power up
Door close interlock switch is out of adjustment. Remove side panel(s) and adjust it back to a point where it recognizzzzzzzzzes it closed. Bolt eveything back to gether and you be done!
Jul 17, 2010 | LG Washing Machines
LE light flashes LG WM-2077HW Front Load Washer
most likely a defective motor hall sensor. 1st try unplugging power cord. it may reset.
Jun 13, 2010 | LG WM-2077C Front Load Washer
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
Feb 12, 2009 | LG WM2487HA Washer
LG WM-2277HW Front Load Washer Logo
333 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
