Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
Sterling shower stem replacement, anyone know how? I changed it out, hard to turn, and slips at times
    Scholar:
  • 102 Answers
Sterling like many others made many different types of faucets and stems. To service any of them you need to remove the handle. Then depending on the type of stem you can make your repairs. Most common Sterling stems were brass. Most common cause of slipping is stripped broach on stem and or handle. The broach is the star shaped part of the stem that the handle slides on. If it is stripped replacing the stem and or handle should do the trick. As for the tighteness of the stem, this could be the packing nut on top being to tight or stem may be damaged. Hope this helps. Please share a vote if it does.
Posted on May 06, 2010
  • Dane Kimball
    Dane Kimball Mar 19, 2014
    I need to replace my shower handle because it has come loose. We had someone come "tighten" it but it came loose again. I think it would be best to just replace the whole thing completely. Looks like I'm gonna have to call a plumber. Central Plumbing Specialties Co.
How do you remove a cartiarigde from moen shower body (single handle)
There is a special tool that yo can use to remove an old and stuck moen cartridge and they can found at your hardware store. Now before you remove the cartridge be sure to remove a small brass or copper pin located at the top of the stem. you will see a groove in the stem cover where the pin is located. once the pin is removed hookup the puller and remove stem. sometime you are able just to grab the stem with a pair of pliers and give a good pull and twist to get it out. don't pull to hard to damage the plumbing in the wall. good luck and I hope I was able to help. As always, TURN OFF THE WATER FIRST...
Feb 11, 2011 | Moen & One Handle Tub & Shower Faucet
I have a very old single valve peerless tub/shower faucet that leaks out the spout when turned off. I removed the knob and there seems to be a plastic part that surrounds the stem and may also serve as a...
im sorry i dont know how to explain step by step what you have to do but i know what you are talking about and its called a diverter. they get stripped out and thats why the spout leaks. they are not difficult to replace depending on the model but some of them have to be sweat apart with a b-tank.
Feb 05, 2011 | Delta Faucet Peerless& Shower Faucet...
I have a Sterling 1500D shower door, the door has rubbed against the hollow bottom seal and ruined it- I can re adjust the door, I need the part number for the hollow seal kit.
I have the same problem. I'm doing research today, I'll keep you posted. unless you already figured out where to get the seal, please let me know.
Nov 20, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
How do I replace a seal at the bottom of my shower door. I was recommended by a Lowe's employee to use seal #RPK2800-S Genuine Parts Sterling. Having a hard time figuring out if the seal slides into the...
I know this is an old thread but posting the answer for the sake of everyone else who are looking for the same answer. Once you pull the old one out, you can slide the new one right in without having to remove anything else. The RPK2800-S has a T top, so just line it up with the opening on the button of the door and push it in. Basically do the opposit of what you did when pulling the old one out. Easy task and should not take than one minute.
Nov 12, 2010 | Sterling Home
Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Problem with Sterling stem.when transfered to shower,still leaks
You did not tighten the stem enough, allowing the seat to rise just above the cavity where it will sit. You may also have scaling in this area preventing the seat from sitting flush.
Feb 03, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
The sterling knob is lost from our bath tub fixture. It is about 3" H by 1" wide at the center. Where can I get a replacement. I live in zip code 17602.
You can call Sterling Customer Care Center at 1-800-STERLING (1-800-783-7546) in the U.S. or 001-877-680-1310 in Mexico. Also some stores stock replacement part kits in the hardware/shower door aisle. Ask a store associate for assistance and depending upon the warranty period of your door, the part may be replaced free of charge.
Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Jan 02, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
No water coming out of shower in master bath
Judy,
Depending on the the architect there may be shutoff valves located in a wall with an an access panel covering them as the past owner may not have used the appliance often. Assuming you have owned this unit for some time and it suddenly quit working you may have a defective stem on a single handle unit. Their are also some valves that have shutoff screws located beneath the cover plate which may also be the problem. If you can provide more info such as how long you have had the unit, when it stopped working, and type of valve and model I may be able to assist you better. Lok forward from hearing from you and thanks for using Fix Ya.
Jim
Nov 17, 2008 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
1,181 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
