Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
No motor noise. Tried reset button; motor noise for a few seconds then nothing
  • 122 Answers
First, with the switch OFF, take the allen wrench that should be with it and stick it into the bottom and center of the disposal. Turn it some left and right to free up anything that might be causing it to seize. Then make sure the motor is reset and try again. If that fails to fix it then it is time for a new one.
Posted on Feb 02, 2010
Why does it pop the reset button?
The button is a current overload protection for the motor. There is a variety of causes. Defective motor windings, carbonized burnt pressure switch contacts, loose connection (e.g. cord to plug, switch terminals, motor terminals), wrong voltage supply to the motor, worn motor bearings, drive belt too tight, or defective driven machine.
I would run the motor with no load, remove the belt or coupling to the compressor pump, and read the amperes and compare to the motor nameplate rating, let it idle a few minutes and listen for bearing noise. By reading motor amperes or current while the compressor is still connected to the motor, it can be determined if the reset button/overload protector is weak. Check every electrical connection for discoloration or overheating and repair if any are found. Check the contacts of the pressure switch. If nothing wrong is found and the motor is just overdrawing current or amperes, then it is time to replace the motor, probably due to a weak or defective motor internal winding.
May 27, 2015 | Air Tools & Compressors
HP 1315 printer won't turn on
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Apr 20, 2014 | HP Photosmart 8450 InkJet Printer
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
Car still wont start tried everything what else could i try any sugggestions?
Hi, Check the solenoid that is attached to the starter motor. That is the most likely cause. Check connections and/or replace solenoid.
There are lights that do come on but shut off after a few seconds when the care is running. There is no reset button that I know of. Have your mechanic check the starter motor as well. Good luck.
Nov 30, 2011 | 1998 Toyota Camry
I had my itouch in my purse for a few days and didnt do anyything that i know of to break it, then the next day i went to turn it on and it wouldnt turn on so i figured it was dead, then i tried pushing...
Try a hard restart,
To reset the iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Also be sure to leave it plugged in to charge for a few hours - you may have completely drained the battery.
Mar 09, 2010 | Apple iPod touch
Maytag MDE9316AZW Clother Dryer won't start
Make sure that nothing has gotten caught up in the blower wheel which is located in the exhaust housing at the front section of the dryer. You can try turning by had and listen for noise, but sounds like something may be in the exhaust housing. If not it will be motor.
Feb 01, 2010 | Maytag MDE9316 Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Reset ge model 169165 electronic cleaning cycle
Unplug the coffee pot and push in the "1-4" and "TSB" buttons at the same time, hold the buttons in for a few seconds. This will reset the pot and you should be able to brew like normal after that.
Dec 07, 2008 | GE 106591 Coffee Maker
Nikon d100 locked
Have you tried to reset the camera? I seen this a few times .. and the camera reset did the trick. I've never heard of the motor noise though.
Oct 20, 2008 | Nikon D100 Digital Camera
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
213 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
