Question about Dishwashers
Dishwasher not heating water
Switched on yesterday. Later, it did not sound right so I opened door. Dishwasher had no water in but pots were very hot. Fixed water problem this morning but now washer goes through it's cycle but water does not heat. I first thought element but I checked that out and found it to be O.K.
  • 833 Answers
You may have an overheat sensor in this unit. Usually, they are small buttons about 3/4 inch in diameter secured to the bottom of the tub and having two wires attached. Find and replace it.
Posted on Feb 18, 2008
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
My dishwasher has stopped cleaning plates properly. It makes everything wet but at the end of the cycle the detergent block is half dissolved at the bottom. I have just run a cycle and opened the door...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
kjh;lkhjk
Mar 27, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Not cleaning low pressure smells hot looks like
Sounds like the dishwasher is not getting enough water during it's fill cycle due to low water pressure on supply line or the dishwasher pump is not working correctly. Could be obstructed with food matter, etc.Hope this helps
Jul 30, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
WIRLPOOL DISHWASHER COLD WATER CLEAN ONLY!!!
HI Nick- the element in the dishwasher dries the dishes and sometimes boosts the heat of the water. Your water should come in already hot, so the problem is either your hot water heater or that the plumbing line was switched to cold by mistake. Or that people are bathing, laundering, etc. and using all available hot water right before you run the dishwasher.
Oct 07, 2008 | Whirlpool DU912 Dishwasher
Smell of burning
The Element is shorting out, tripping the rcd. replace the element, thermostat,and any cut outs that are in the element cricuit. The element should not be glowing which means the stat is shot and the safety cutout for the element is shot also, while you`re at it check out the circuit board for dry joints, discoloured resisters, bulging capacitors etc.
This is VERY dangerous situation, as the machine has the potential to set your house alight and burn it down!. If you continue to use it in it`s current condition you may well damage other componants - rendering the machine B.E.R - Beyond Economical Repair. I will will advise You to never to leave this machine unattended, do not go out after turning it on and have a nice afternoon in the park etc, you may well come home to a pile of ashes!
Feb 18, 2008 | Zanussi ZWF1430W Front Load Washer
My tablet won't dissolve.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
May 16, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
