Question about Beeman Optics
Beeman scope lost caps where you adjust the cross hairs
5 Suggested Answers
cutlassguy
  • 16 Answers
SOURCE: SIMMONS 3X9X32 BLACK RIFLE SCOPE
check to make sure it hasn't turned in the scope rings. I am sure if it is somewhat new simmions will fix as long as it falls within warranty
Posted on Dec 15, 2008
  • 75 Answers
SOURCE: cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Posted on Apr 28, 2009
miket756
  • 2702 Answers
SOURCE: i have a tasco 4x32 rifle scope and the cross
you dont fix a tasco scope there so cheep you just throw them away,, and buy a new one,,,sorry but thats the way it is with tasco
Posted on Nov 17, 2009
miket756
  • 2702 Answers
SOURCE: my simmons scope cross hairs have turned diagnally
it is repaireable but its going to cost more that a new scope,, your one has shook its self apart,, to fix it it needs to be striped right down all the glass will need to be cleaned and after the repair it will need to be refilled with gas,,,,so its not worth the cost of a repair,,sorry
Posted on Nov 18, 2009
How to reset bushnell elevation adjustment to zero?
If you want to center the cross hair in the scope
Rotate elevation down to it stops then count up clicks to it stops then half number and rotate down that number then repeat with windage or you could use two v blocks and view a point through the scope and rotate scope and adjust cross hair until no deviation from a fixed point up or down left or right
Hope this helps
Dec 07, 2014 | Bushnell Optics
Exploded diagram
You don't actually adjust cross hairs, you adjust point of impact. You do this using the turrets located near the center of the scope. the top one will adjust height, the r hand one will adjust windage.
Feb 21, 2014 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
My cross hairs do not move when i adjust my sights. i bought a laser bore sighter and the laser points in the same exact spot no matter how far i turn my adjustments nor do my cross hairs move.
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
Jan 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
Sep 19, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Cross hairs turn when adjusting power
Sounds like somebody took your scope apart and forgot something. You can remove the rear of the scope, but you might want to send it back to the factory. Some scopes are filled with nitrogen to stop them from fogging up, But maybe only the front part. Take the eye piece off, you should be able to get to the cross hair unit, it should come out in one piece, find out why it spins, might be missing a washer, I have replaced the cross hairs on scopes before with spider webs, I tried a dolls hair once, I thought it was thin enough, .002 ",, It looked like a rope inside there when I got it back together. Good luck, let us know what happens.
Feb 14, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
My rifle hits the same spot no matter how i adjust it
there should be two adjustment dials on the scope one on top and one on the side might be covered with a plastic plate, depending on the scope the top dial does elevation, and the side dial does left and right adjustments
Dec 30, 2009 | Beeman Optics
I have a 3-12 by 40 rifle scope made by tasco i dont have thewaranty paper work any more and the cross hairs wont adjust any more what do i do
i dont realy understand what you mean by "the cross hairs wont adjust" is it you have ran out of adjustment on the turrets? if so try packing the scope out with 35mm film under the body of the scope and reclamping it,,,or do you mean it just wont adjust?
the tesco rifle scope is a realy cheep scope its a throw away kind of thing if it brakes,,,,there only £50 or so,,,,if it was a £1500 scope its worth fixing
Nov 16, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
I am trying to bore sight a rifle with a center point 4x16x40 and i run out of adjustment to get the lazer to align with the cross hairs
When bore sighting you need to adjust in small steps and "TAP" the bore or the main body of your scope to cause a golt, as when shooting your gun it will kick and cause the scope cross hairs to take their set.  Tap it with a med sized screw driver handle. Make a small adjustment and tap it, adjust and tap.
Sep 23, 2009 | Centerpoint Technologies CenterPoint...
Optics Logo
93 people viewed this question
Top Beeman Optics Experts
Mark Campeau
Level 1 Expert
Andrew Taylor
Andrew Taylor
D. E. Hev
Are you a Beeman Optic Expert? Answer questions, earn points and help others
