Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
I have a Sony rear projection TV model KP-46WT500 that is 6 months beyond the extended warranty! and I believe a power surge blew out the TV- made a snap noise and picture is now concave (small top/bottom in center and large on edges) and the 3 color guns can be seen "off" of each other. Can I fix it? Myself?
  • 1 more comment
  • Sassy2 Feb 19, 2008
    I have not found your convergence IC replacement yet...
  • Sassy2 Feb 22, 2008
    i DO NOT HAVE SOLDERING EQUIPMENT SO IT LOOKS LIKE I CAN NOT FIX THIS
    No unfortunately I'm in Mich. Can I replace a module without soldering?
    Sergeant:
  • 261 Answers
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Posted on Feb 18, 2008
  • 1 more comment
  • Jay Henderson
    Jay Henderson Feb 19, 2008
    Are u up and running now?
  • Jay Henderson
    Jay Henderson Feb 22, 2008
    Sorry i couldn't help u more. But i am grateful that my convergence tip helped you out. :-) I am located in Louisville Kentucky. Are u near there at all? Maybe i can schedule a service call for you. Let me know.. Guru Jay
  • Jay Henderson
    No, sorry unfortunately not. But does the set look 3D? I would suspect that the convergence ic is bad.
How to go in service mode for tv sony kp-46wt500.i did change the stk ic,the convergence is good in the midle but bad on the side
Did you replace the pico fuses on the G board there are two and usually one will blow when the old ICs fail and just replaceing the two ICs on the D board will usually not fix the issue untill the two pico fuses are checked and the blown one is replaced.
Mar 20, 2012 | Sony KP-46WT500 46" Rear Projection...
The picture is red ad green shadow and the word are also repeat red and green shhhhhhhhhhhhhhhhhhhhh bad sont tv
Blue Jet drive is blown. This will need replaced and the TV will need re-aligned. This may cost more than the set is worth.
Aug 27, 2011 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
My sony projection tv model # kp-46wt500 has a green and red tint. how can i fix it?
Increase the current flow to the blue color gun. If it is not adjustable it will need replaced and this is a major repair. You can try to reduce the red and green guns and increase the output transformer for a temporary fix, but save up your pennies for a replacement. Have a tech look at it before running out for a replacement because the SONY is the better model projection televisions.
Jun 28, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
