Question about Sewing Machines
Problems with thread tension.Cant grt any tension
I Have a problem with the needle thread tensioner,Can't get tension . I don't know if it's properly assembled or not Can you help? thank you.
  • 255 Answers
It's probably assembled ok. If you're trying to adjust the tension with the pressure foot up, it won't work. The pressure foot needs to be down in order to adjust the tension.
Let me know if this works, ok?
Posted on Jan 31, 2010
Breaking thread and under thread is loose
Is this happening when you are free motion quilting? Do you have the right needle size, thread.
If you are talking about the thread on the bottom of the fabric being loose it is actually the tension on the top thread. The tension is too loose. You might want to check and make sure it is threaded properly and that the thread is between the tension disks. The slightest thing off will make it not operate properly.
You need to relax and take your time learning your sewing machine. Once you do that you will immediately know what to adjust or check.
Jul 05, 2017 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
All time thread was broken
possible threaded wrong .
Mar 05, 2016 | Sewing Machines
I just got my sewing machine 2 months ago just started to use it icant because it keep breaking the thread ihave a fleeling i have it sat up wrong like the teason als may be t o tight thanks Jan from
***Upper tension setting
*** Put the pressure foot up.
***As you are threading give little tugs to check for snags. Snags must be fixed.
***When finished threading (not the needle) put the pressure foot down.
***Check the tension by starting at zero and increase the tension slowly and give small tugs to see if the tension is rising. (This is all done without the needle being threaded)
***When you feel comfortable this is working then thread the needle and set the tension at four.
***Set the bobbin tension. Attachment gives instructions.
Now that all of the tension has been set you can try for
Sep 30, 2015 | Singer Sewing Machines
How can I get the monogram to work properly?
On my sewing machine that would be an indicator of misadjusted thread tension. Changing thread type or diameter generally requires tension adjustment. In this particular case, I\'d increase the bobbin tension a bit (if I understand your description correctly, the bobbin thread forms loose hoops), and back off on the upper (spool) tension (pulls too hard on the thread). On one or two of my bobbin cases, I had problems with the tensioner screw working loose during use. I put a dab of nail polish on the screw head to stick it to the bobbin case. Problem solved.
I\'m not familiar with your particular machine, but I don\'t see why you can\'t make the character any size above the minimum (which would be the smallest readable character that can be made with the stitch length and type used).
Apr 24, 2014 | Kenmore Elite Clothsetter 19010
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 17, 2012 | Janome Sewing Machines
Brother sewing machine xl2600
Don't worry! I'll try my best to help out here. Problem is most likely in bobbin area. Remove bobbin, clean with brush to remove any threads caught in tension discs. Brush the feed dogs (teeth area under your needle plate).Rethread with presser foot in UP position so thread can locate tension slots. I recommend new needle and remember to push it up into needle bar shaft flat side back a's far a's it will go. Tighten needle clamp screw. That press foot must stay raised now while you insert needle And thread it. Tension: Set at 4. Just a very short turn of tension if 4 is not giving desired results. I hope this helps. It's probably very frustrating, I understand, but I know you can remedy this easily. Follow above steps SLOWLY! Jimmy
Apr 03, 2012 | Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
Good day!
Jun 08, 2011 | Husqvarna Freesia 415
Mylock 134d janome
make sure the needle is pushed in properly.
Jun 24, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
166 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
