Question about Indesit W 123 Front Load Washer
Fault code f-05 - Indesit W 123 Front Load Washer
  • Indesit Master
  • 3,463 Answers
Error code F05 denotes the pressure switch is jammed on full.
Remove lower rear cover of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
PT cruiser 05 engine light is on what should I check for
When the engine light is on it means the management computer has detected a fault and switched to a get-you-home programme. The fault will be stored in the memory and a scanner or code reader will be needed to extract the code number and details of the fault.
Mar 19, 2017 | Cars & Trucks
Suddendly start running rough and worser on overdrive. Iused scanner it showed p205,p2609and p2149.Please tell me what to do.
Dodge Ram 3500 Questions - I have an 05 ... - CarGurus
www.cargurus.com > Questions > Dodge > Ram 3500
CarGurusAug 28, 2012 - I'm getting a code P2149 fuel injector group B supply volt... ... I'm getting a code P2149 fuel injector group B supply voltage circuit/open. ... 2005 dodge ram 1500 won't move when in gear 38 answers.
Question on codes p0202 and p2149 - Chevy and GMC Duramax Diesel Forum
www.duramaxforum.com > ... > 04.5-05 LLY Duramax Powertrain
Dec 5, 2009 - 6 posts - ‎4 authors
Hi got a 05 3500 running really ruff and throwing 2 codes p0202. ... Number #2 injector Drive fault, incorrect current on a fuel injector circuit (the ...
breaking down on freeway code p2149 - Chevy and GMC Duram
Dec 05, 2015 | Cars & Trucks
Error F 05 what is it indicating?
www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html whirlpool
Jun 26, 2015 | Washing Machines
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
150-05 fault code
Speed Shift sensor "door" open???
Or speed shift sensor circuit open???
Keep us udated and send us additional details about yea, brand and model and engine sizes.
Feb 09, 2012 | Cars & Trucks
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
Jd 05 i think 4310 wont move fwd or rev trouble code flashes four times one short ,long, short, short?
This is fault code 1.Fault-forward pedal.Cause of fault-Voltage signal out of range.Result of fault-Output current zero machine does not drive.Required action-get signal in range,,,recalibrate sensor.If this code does not match up to your symptom let me know and I will look into it.
Nov 19, 2009 | John Deere Garden
Fault code f-05
make and model of the washer, codes are not generic
Oct 04, 2009 | Washing Machines
Fault code or engineers reset for beko washing machine wma 756s serial no 05-100 905-06
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
Dec 21, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
358 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
