Question about Sony Car Audio & Video
Unhooked my amp, killed the batery and protection light came on... charged battery and amp still wont come on???????
    President:
  • 2,047 Answers
Check if battery was properly charged...if yes then check the amplifier fuse...it could be burnt..
Posted on Jan 31, 2010
My xbox 360 controll wont turn on unless my rechargable batery is fully charged
just buy a plug in and play that should solve the problem and keep the plug in
Jun 18, 2012 | Microsoft Xbox 360 Controller
My kawasaki zx12 wont turn on.i've check the batery cables and ignitoin.it happened when i installed a new battery
A couple of things that may sound trivial or silly, but check and make sure your kill switch is in the start position.
Check your fuses to make sure they are all still good.
Make sure that when you turn the key you get a neutral light, if not select neutral and try to start it again.
Check you battery is fully charged, a battery that is below charge won't start a bike like it will start a car.
Did you disconnect any other wires if so reconnect them.
Do you have fuel in the tank?
Sep 18, 2011 | 2003 kawasaki ZX-12R
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
Batery wont charge new alternater and batery the batery light does nont come on in the dash
Check the 30 amp alternator mini fuse (#26) in the engine compartment fuse box by the battery. By the way, if you don't have an owners manual, you can download on here: http://www.motorcraftservice.com/pubs/content/~WOVSAB/~MUS~LEN/40/97sabog1e.pdf
Dec 04, 2010 | 1997 Mercury Sable
The body shop unhooked my car battery and know my anti-theft system is locked . how do i unlock it . they said something about they unhooked my alarm. PLEASE HELP!!
This worked on a 2000 so try it and see if it works on yours.
Disconnect both battery wires and "short" them together. This kills stored memory.
(1)Turn key to crank & then release. Security light still on. Wait till it goes off (maybe 15 minutes)
(2)Turn to off. Repeat step one.
(3)Turn to off. Repeat step one.
(4) Turn to off. Wait 20 seconds and start car.
Key must go to full off on each pass. Must have fully charged battery. Good Luck.
Even if this does not work a good testimonial would be appreciated
Nov 25, 2010 | Saturn Ion Cars & Trucks
I got Nokia N99i chinese version cellular phone with 2 batteries, one battery worked for 3 months & now charging isn't holding & other battery can't charge since bought. How can i buy a new battery...
Men you really got a problem!
ok Try Ebay, if not www.alibaba.com sure you can find the batery there.
Other ways:
the batery its not charging at all?
you can buy a Universal Batery Cell phone carger, these ones got the ability of charge some times baterys whit thiis kind of problem.
Make an adaptation from other batery (just look details as Voltage, amps) sometimes its require soldering directly to your phone :S (pretty extreme)
Oct 17, 2009 | Cell Phones
Bike will not start no power
Touch a 12" piece of wire to one terminal then touch the other end of the wire to the other terminal. Got a really good spark? No spark = bad battery. Okay, so you do get a good spark. Check the wiring harness for an unplugged wire. Also check for loose connections and burned wires. Bad ignition switch? Kill switch turned on?
Mar 13, 2009 | 2005 Honda CBF 500 ABS
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
