Question about Kenmore Dryers
Drum will not turn but belt is not broken - Kenmore Dryers
    Novelist:
  • 132 Answers
The first thing to try is opening the door and turning the drum by hand to see if it turns freely, you may have something lodged in the front or back seal areas wedging drum. This is unlikely but easy to do without taking apart dryer.
Some have a glide tightener instead of a roller assembly tightener which are two styles of belt tighteners used. Glide type should be replaced by the roller type and a new belt.(glide type tends to cause belt stretching)
These are things to look for assuming motor is running and belt did not just jump off, which is rare, need to disassemble by lifting top and removing front to work on, with unplugged. There are sharp edges on inside of dryer, so watch out for sheet metal edges.
Posted on Jan 31, 2010
My dryer just started making a loud sound and the drum isnt turning
Could be the drive belt has come off or is broken or if it is gear driven, then it's possibly the gearbox has failed. New belt a piece of cake, new gearbox?, time to price it against a new dryer.
Dec 05, 2014 | Haier HLF11P 6 cu.ft. top load washer /...
I have an eziloader 6kg dryer, the drum does not spin but the heater element turns on. How do I check if the belt has come off?
can you turn the drum reasonably easy whilst the machine is empty and off . If you can than the drum has no load and the belt is either broken or has come off the drive pulley or the drum . Disconect power cord from socket and remove back off machine ..You know should be able to access drive belt and either replace belt onto drum and drive motor or purchase and fit new belt . It is a good idea to replace a belt that has slipped off and is not broken - belts stretch and its likely to come off again . If this is one with a sealed back then turn it on side and remove base to reach belt .
Aug 13, 2011 | Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
My dryer is heating but the drum is not turning, what is the problem?
What you are describing usually means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 while the machine is off put your hand inside the empty drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
http://www.fixya.com/support/t6322596-get
Hope this helps,
Best Regards,
Mark
Jan 21, 2011 | Dryers
Tub stopped turning, connot turn by hand either.
Dryers have a belt that turns the drum, I think dryer belt being broken or slipping badly, burn out motor, or worn support parts.
---Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it. ---You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it. ---Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Thanks..!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 06, 2010 | Maytag Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Belt broken, drum wont turn manually
if your drum will not turn manually, then the motor is seized up, or a sock is caught in the blower wheel...
Sep 15, 2009 | Dryers
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 | Dryers
Dryers Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
