Question about Cell Phones
How do i delete net text messages on my nextel i730??
I had an old nextel phone it was a i730 and i had to go on the internet on the phone every time i got a text message and i just got a i290 and i still have to go on the internet to send and receive text....
The Text messaging on the I290 is based on Java technology the requires you to go use the web portal..
Newer phones like the i776, i465,i410,i9,i856 no longer require that...
May 20, 2010 | Motorola Mobility Boost i415 Cellular...
Trying to send a text message from the nextel I710 motorola phone but text message is not an option under messanger center list how do i send text?
To send a text message for the i710, you may need to go to WEB, and go to send text message, there should be an option for this. Recommended that you get a texting package, due to it may run $0.15-0.20 per text. Let me know how it goes,
Thanks
Justin
Please Rate Me :)
Jan 09, 2009 | Nextel i730
How to take off text message signatures nextel i710
I have seen this issue MANY times before, what I can recommend for this exact problem, is to Reset to Defaults. Which will delete all your Downloads/contacts/saved info. This option should be located in menu-settings-security, password should be 000000 unless you have modified it. the option will either be, Restore Defaults, or Reset to Defaults.
Let me know how it goes, thanks
Justin
Please Rate Me :)
Nov 23, 2008 | Nextel i730
Text messaging
go to net in the menu and go to text messaging and you should be able to go form there
Jul 11, 2008 | Nextel i730
Text messaging with an i730
With this problem, you should be able to Delete the SENT msgs by either going to the sent menu, and choosing OPTIONS, and delete all, if the option is not there, you may need to delete them under the Settings on the phone, for the SENT ADDRESS, you should be able to simply chose either back/delete any of those options should work well. Please let me know how it goes
Thanks
Justin
Please Rate Me
Apr 24, 2008 | Nextel i730
I have a nextel I730
If you have a texting package, it is simple * even if you don't, it is the same options, just keep in mind, it is $0.15-.20 Per Txt * Menu - Web - Send Message Or Text Message
Thanks
Justin
Please Rate Me
Apr 03, 2008 | Nextel i730
How to text message on a i730 nextel
i cant text at all on the nextel i730.idk how to get started on it
Feb 20, 2008 | Nextel i730
I730 starting a text message
im having the same problem
Feb 18, 2008 | Nextel i730
Text Messages
You can only use SMS messages on that phone. Go to web and select text messaging, in order to use text.
Oct 15, 2007 | Nextel i730
I530 text messaging issue
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
Sep 25, 2007 | Motorola Mobility i530 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
