Question about Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo turn on and screen goes black - Daewoo L700C 17" Flat Panel LCD Monitor
3 Suggested Answers
Marca
  • 5 Answers
SOURCE: black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: screen turns black
problem with the inverter chek it
Posted on Feb 10, 2009
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical bar on Daewoo Plasma screen
The main problem of this model is VPB (video process board) and the reason is they build in it SMD capacitors and they are always crap.First thing that you guys should do is to replace them all but not with SMDs,get a normal capacitors same values.And of course replace all capacitos on PSU.Parts are cheap to buy about 30euros,work on the PSU is easy,only the VPB is tricky but it can be done.It only takes time but belive me don't even think of board replacament its cheeper to by a new set
Jan 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Black screen
1. Bad video card
2. Bad video cable
3. Bad monitor
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo L700C 17" Flat Panel LCD Monitor Logo
63 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Paul Bade
richie46
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
