Question about Aastra Telecom Aastra 9110 Single Line Corded Telephone (AASTRA9110)
How do I set the time and date on this telephone?
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Posted on Feb 19, 2008
Aastra 9110 message light doesn't light
were you able to get this working? hat did you have to do?
Dec 07, 2012 | Aastra Telecom Aastra 9110 Single Line...
I can't remember my password to access messages on my M6320
Your provider will have to reset it for you. They may charge you for it though. That is the only way
Feb 28, 2012 | Aastra Telecom Aastra M6320 Single Line...
How to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Feb 28, 2011 | Aastra Telecom Aastra 8314 Corded Phone
Cal do you use the call forward feature on the AASTRA Telecom 9316 CW telephone to forward calls to another coworkers telephone number.
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
Nov 01, 2010 | Aastra Telecom Aastra M9316 CW Single line...
I am only using line 1 on the aastra 9120, how do i get "check line cord line 2" off the display?
i have the same issue. considering the following solution; install a splitter to connect both phone ports to a single line.
Sep 24, 2010 | Aastra Telecom 9120 Corded Phone...
How to I forward a number from one phone to another?
If your phone company provides the service, you should have a code to enter. If YOUR telephone switch is doing the forwarding, you will also have a code to enter.
Basically, you enter the code, then dial the number and hang up. To unforward, you dial a similar code, and hang up the phone.
May 06, 2010 | Aastra Telecom Aastra 9110 Single Line...
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
May 04, 2009 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra Telecom Aastra 9110 Single Line Corded Telephone (AASTRA9110) Logo
255 people viewed this question
Top Aastra Telecom Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
voyager663rd
ray gallant
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
