Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore model 596.57542791 side-by-side leaks from the water dispenser on the front door. What parts and how do I acess?
Water started dripping from the bottom of the freezer door.
Posted on Sep 27, 2012
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
  • 51 Answers
SOURCE: leaking water out of the front freezer side
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
SOURCE: Kenmore Elite - bottom Freezer - water leak from refrigerator
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
Posted on Jun 25, 2010
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side fridge with ice/ water dispenser in the front door. When I push the water dispenser the water comes out the spout but also some comes out behind the spout making a mess. Is...
sounds to me that the line inside of the door is cracked. Their is no easy way to repair that, either the entire door must be disassambled to replace that line,or replace the outerdoor panel with the line embedded into it,to replace the door panel it requires transfering all the compentents fmor old to new door panel, a partial list of things that must be transfered parts from old to new outer door include but not limited to
inner door panel
door gasket
dispenser asm (which cant come out as one piece and must to disassabbled into appx. 20 parts)
wiring
hinges
door handles
Jul 26, 2011 | Kenmore Side by Side Refrigerator
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Nov 04, 2009 | Kenmore Refrigerators
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Dec 31, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak????
umm the leak is coming from the seal within the front of dispensor??? i checked my partlook up and comes back as a seal( part number 8181747).. sears site has it listed as distrubution nozzle(mis marked)
Oct 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
