Back to:
Tags:
Microtech JTX V5 15 in. Flat Panel LCD Monitor
My monitor has built in speakers but I can't seem...
posted by Leslie65038 on Feb 18, 2008
JTX V5
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 20, 2008
Not Rated (0)
kishkane
Rank:Wiz Wiz
Rating: 74%, 106 votes
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my monitor has built in speakers but I can't seem to turn them on:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Monitors
i have done this before connected me laptop to my moniter...
Monitors
Bro from where are you? got the same problem but finally...
Monitors
I have cracked my 19" HP monitor (works fine still)...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
