Question about HP Pavilion dv6000z Notebook
Screen doesn't work
When I turn my notebook on, it beeps 3 times. the first one is longer than the others. the screen doesn't work, but the laptop is working because I can hear the sound when windows starts. one day was working normaly and the next day not anymore. Could you helpe me?
  • sanu sabu May 11, 2010
    Are the screen loose
    Scholar:
  • 163 Answers
If the lid switch isnt stuck I'd look to the Inverter to be bad. Check on external monitor to verify Video there however.
Posted on Feb 19, 2008
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
My dell inspiron beeps 20 times at sturtup
I wonder if you have a keyboard issue. Most times the constant beeping means the keyboard is bad, but it doesn't normally boot or revert back to 5 or 4 beeps.
May 08, 2012 | Dell Inspiron 6400 Notebook
My HP DV6000 beeps 4 times and I end up with a black screen and the power button Flashing
Most likely a memory problem. If you have more than one stick of memory, remove one and try it.
If that doesn't work, remove the other one and replace the one you took out.
Nov 01, 2011 | HP Pavilion dv6000z Notebook
When i try to turn it on it beeps 3-4 times and nothing appearsm on the screen. but i can hear it running
Beep codes will site specific problems. Say it beeps 3-4 times is not specific enough.
One suggestion is to remove the disk drive, memory and any other device. IF the system is OK it should boot to a BIOS screen. If it doesn't, you probably need to replace the computer.
If it boots to BIOS, one at a time replace each component and try to restart. That will identify the failing device.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 27, 2011 | IBM ThinkPad T30 2366 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
May 14, 2009 | HP Pavilion dv5-1000us Notebook PC
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Think pad 600x screen
If 3 beep....if I'm not wrong its a VGA chips problem.You need to send the board to check.But first what I recommend is try to remove external hardware one-by-one.Like memory,DVD,..
after remove one-by-one try to tuun on and see.If it doesn't work then its a VGA chips problem.
Goodluck,takecare.
Apr 04, 2008 | IBM ThinkPad 600X Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
