Question about Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
  • 619 Answers
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Posted on Jan 31, 2010
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
Stackable kenmore washer dryer
could be a clogged pump or drain hose causing the water to spin over the top
Jan 15, 2013 | Washing Machines
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
Noisy dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 15, 2010 | Kenmore 98702 Stacked Washer/Dryer
Sears stackable one peice unit. washer top load on bottom and dryer front load on top. The proble is when the washer is in the spin cycle it make a teriable load noise. Like it is grinding becase of a...
Your brearings are possibly worn, when the machine is off open the door and grab a hold of the drum (metal part on the inside) lift this drum if your bearings are worn it will have some play within its housing, i.e. it will move before the inner tub does and mannually rotate it you should here the bearings rumble if so also. they wear over time. you may be able to get them replaced but check prices first as it may be cheaper to get a new one bearing changes can be labour intensive.
Sep 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer dryer. Dryer is not heating up. I need to find how to replace the element
The element is behind the drum. You have to remove the front panal and pull the drum out.
Eric
Jun 10, 2009 | Kenmore Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
185 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
