Question about Singer 7462 Mechanical Sewing Machine
My singer starlet 353 is giving problems. The thread keeps breaking and I have no instruction book.Please advise which settings I should have each control on to do both overstitch and regular stitch for hems.
  • 980 Answers
Remember that early Singer machines would only sew properly with number 40 or 50 mercerised thread, anything else and all sorts of things happen, top tension should be about 4 or 5
Posted on Jan 31, 2010
  • 340 Answers
Hi, you can download a free manual from this site
http://sewingonline.co.uk/instructions/singerstarlet/
They have loads of other sewing machine manuals.
Posted on Aug 22, 2010
  • hazelgrace
    hazelgrace Aug 23, 2010
    Sorry, I made a mistake. You can view the manual online for free but it costs about 5GBP to download. Perhaps you can save the images onto your computer by left-clicking on your mouse?
4 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: singer 251-2 industrial sewing machine
It was a tough find but here is your manual:
http://www.bestneedles.com/catalog/singer/Singer%20Instruction%20Manuals/251-Class-Inst.pdf
Posted on Dec 10, 2007
  • 351 Answers
SOURCE: singer overlocker model 14u34b user manual
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
Posted on May 14, 2010
Tally Girl
  • 1122 Answers
SOURCE: I am trying to do
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Posted on Jun 26, 2011
I just got my sewing machine 2 months ago just started to use it icant because it keep breaking the thread ihave a fleeling i have it sat up wrong like the teason als may be t o tight thanks Jan from
***Upper tension setting
*** Put the pressure foot up.
***As you are threading give little tugs to check for snags. Snags must be fixed.
***When finished threading (not the needle) put the pressure foot down.
***Check the tension by starting at zero and increase the tension slowly and give small tugs to see if the tension is rising. (This is all done without the needle being threaded)
***When you feel comfortable this is working then thread the needle and set the tension at four.
***Set the bobbin tension. Attachment gives instructions.
Now that all of the tension has been set you can try for
Sep 30, 2015 | Singer Sewing Machines
How do I thread a singer professional XL 50
contact singer about a video or try youtube
Nov 03, 2014 | Sewing Machines
Singer 3221 complaints and comments
Check the machine's paperwork. It could still be under warranty.
Hopefully, your sister oiled per the manual instructions. Oiling a computerized machine is not advisable unless the instructions say to do so.
Ask your sister to try something:
Remove the top thread from the machine.
Install a brand new needle (verify it is facing the correct direction).
ALWAYS RAISE the presser foot and rethread the top thread--confirm it follows the correct thread path.
Set the top tension to the midway point.
Re-test the machine.
Go to the following web site and scroll down the page and read the reviews there:
Amazon com Singer 3221 Simple Sewing Machine with Automatic Needle...
May 28, 2017 | Singer Sewing Machines
Singer user guide starlet 496
Many Singer machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The 496 is not available. However, the manual for the Starlet 495 is available: http://www.singerco.com/uploads/download/8a78e29267b106e9d2902ac0f6758edf694e6d61.pdf . Since Singer doesn't change the machines significantly, this manual may help you.
If the 495 manual isn't enough, this site seems to have the manual for sale: http://www.manualsdrive.com/captching.php?lang=en&search=SINGER+STARLET+496+USERS+GUIDE .
I hope this helps.
Sep 01, 2012 | Singer Sewing Machines
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 07, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
1,025 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
