Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a G.E.M# GSS22JERF-BB side by side The lower half of the refrigerator and freezer is cooling the top half is warm-milk separating.Evap coil in freezer is frozen.
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator and freezer are cold but not cold enough
Make sure the damper is still open and check for another return damper at the bottom. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Jan 20, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator and freezer are both cool, not cold.
Pull refrigerator away from wall unplug remove lower cover and feel top of compressor. If too hot to keep hand there leave unplugged until start components, compresser windings and condenser fan can be checked. Let me know what you find and I can assist you, Thanks, Sea Breeze
Posted on Feb 20, 2010
micromatikal
  • 2777 Answers
SOURCE: Both sides warming up. Refrigerator freezes bottom
How old is the fridge? It sounds like the compressor itself is going bad. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the fridge with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the fridge.
So sorry that I don't have better news but it is definitely a compressor issue and will at least need service, but I recommend checking your options so you don't need to pay for it.
Thanks
Tim
Posted on Sep 28, 2010
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
I have a Armana Refrigerator. Freezer on top...First Edition brand. I hear the freezer fan blowing but to me the freezer seems warmer than it should be. I do not hear anything in the fridge. The fridge...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 13, 2011 | Refrigerators
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The freezer is not keeping anything frozen on the top 2 shelves of the freezer. There is a blinking red light by the ice on/off switch. What does it mean
either the evap motor ( blower ) has quit or there is ice blocking the evap coil / preventing air flow to the top of freezer . . also the fresh food must be getting warmer .. ck the milk .. mm
Feb 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
