Question about Swiss Air-O- 7135 Warm Mist Antimicrobial Humidifier Humidifier
Air-o-swiss membrane coating coming off, is this a
Air-o-swiss 7135 membrane coating coming off, is this a problem?
    President:
  • 2,047 Answers
No its not a problem if you dont mind how the system looks...otherwise just get some oil paint and re-coat it
Posted on Jan 31, 2010
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Where does the silver ion stick go into the unit AOS 7135
In the base on the side opposite of the membrane - see pg 13 of the manual for a picture showing where it belongs.
Oct 10, 2010 | Air-O-Swiss AOS 7135 Humidifier
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I have air-o-swiss humidifier. Recently I cleaned it. Its motor appears to be working after that but the mist is not coming out. Any clues?
When you cleaned it , did you remove water level sensor? If so did you put it back in upside down? The sensor is a plastic cylinder that is held down by a screw and washer.. If you have it in upside down, the empty water red light will be lit,,, if you unscrew the sensor and flip it .. it should start to work again..
Dec 05, 2009 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
I need an online owners manual for AIR-O-SWISS 7135 Ultrasonic Humidifer. Thankyou
Here is the general download page for all AOS manuals and quick set-up guides.
Here is the direct link to the AOS 7135 manual in pdf format.
Oct 01, 2009 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Air o swiss 7135 turns on but no mist comes out...
would you describe your problem in a little more detail please?
Jan 17, 2009 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Membrane on AOS 7135 needs replacement. Is it available?
Customer Questions / Repairs / Warranties / Ordering
Phone 800-336-0326 And the web address is
http://www.airoswiss.net/
some parts available, somethings need to be shipped to them
Jan 08, 2009 | Air-O-Swiss 7133 Humidifier
Air-o-swiss 7135 humidifier not misting
Ours has done the same thing after only 2 weeks. From article research, it appears that this occurs to everyone after cleaning it with the EZ Cal that is recommended. From looking at our unit and figuring out how it works, it appears as though the Ultrasonic Vibration membrane has stopped working. This particular piece is responsible for vibrating the water and making water mist particles which are blown out with the air. We will be calling the manufacturer on Monday to register a complaint and request a replacement unit.
Nov 23, 2008 | Air-O-Swiss 7133 Humidifier
Red droplet light stays on
I had the same problem. I replaced the filter and cleaned the base and then it worked.
Jan 10, 2008 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Air o swiss 7135
sounds like the filter is not allowing air flow.
Nov 26, 2007 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Humidifiers Logo
488 people viewed this question
Top Swiss Humidifiers Experts
Mack Baxter
Dennis
Are you a Swiss Humidifier Expert? Answer questions, earn points and help others
