Question about Car AS9076 Upgrade Remote Start to Keyless Entry
The dealer set up my remote start so that the horn honks 5 times before the engine starts. How do I disengage the horn from the remote start function?
  • dah10571 Jan 31, 2010
    Thanks. I know this is a silly question, but how do I know if it's 'after market'?
  • 1,068 Answers
You will need to go into the program function of the remote start using the valet button. but you will need the user manual and it will tell you what sequence to turn key on and press the valet button. so once you get the name of the remote start i can not help any further seeing every manufacture is different in there settings for programing. let me know
Posted on Jan 31, 2010
    Sergeant:
    Champion:
  • 258 Answers
If its after mrket than u can disconnect it from the horn relay wire harness
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Mar 01, 2015 | Avital Vehicle Parts & Accessories
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Reset key fob
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again
Jul 22, 2014 | Subaru Outback Cars & Trucks
My remote start just stop working on my 2012 mustang gt, the horn just honks 2-3 times now instead of starting
since its a 12 bring back to dealer have them reset program -some of the problems can be --weak battery in fob----if their is a problem that sets off a check engine----battery went dead -----program hiccup but vehicle should be under warranty
Dec 09, 2012 | Cars & Trucks
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Sometimes when I press the starter button, my car with crank for a little bit, then won't start but the car is still on. I normally press the starter button again to turn off the car, then press it again....
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Nov 28, 2010 | 1401 Remote Start/Keyless Entry System
Just purchased a remote on the internet need to know how to program it to my car alarm
turn ignition switch to ON 3 times, leaving it in the ON position the 3rd time. Press the RED VALET button installed under your dash somewhere, 2 times (holding on the 2 nd push) you will here the horn honk, release valet switch, and then press the LOCK button on the new remote. The horn will honk if it programs. Turn ignition off and the horn will honk 3 times to let you know it exited the programming sequence.
Jul 23, 2010 | C3RS603 2Channel Remote Start Module with...
Ford factory installed remote start I open door and truck shuts off what can I do to program this so it works like it should
Follow the following procedures for 2010 Ford vehicles with the door open shut down enabled:
1. Locate the override button and LED. On my escape the override button was at the bottom of the plastic by the driver's knees. The LED is attached to the harness behind this plastic, under the steering column. It is easier to find it once it's on.
2. Open the driver's door, press and hold the brake, turn the vehicle on.
3. While holding the brake, press and hold the override button, after 10-15 seconds the horn will honk 3 times. Let go of the button and the brake.
4. Push the override button until you hear the horn honk 5 times.
5. Push the brake until the horn honks 7 times, this is the "door open shut down" selection. The LED should be on.
6. Push the start button on the Key Fob. Do NOT hold it down, or it will reset everything.
7. The LED should now be off.
8. Shutdown the vehicle, and test it out.
Note: This procedure can be used to change the auto shut-off from 10 to 15 minutes as well. Instead of going to where the horn honks 7 times, go to where it honks 3 times, and turn the LED on.
Nov 19, 2009 | Ford Vehicle Parts & Accessories
My horn used to honk when I locked my 1999 Jeep with the remote
If you have your owner's manual, there is a section that will tell you the exact sequence to press to enable/disable the horn bonk. It has three settings, chirp, honk, and off. The chirp is a really quick chirp of the horn. Honk is a longer honk. Off seems to be what you've set.
I hope this helps.
Aug 20, 2009 | 1999 Jeep Cherokee
Change settings so horn does not honk when arming via remote
If this is even possible...which im not sure..you would be best goin to a dealer..and let them show you how to use your alarm remote..the BUMs show do it for nuffin..Good luck
Jun 16, 2009 | 2006 Chrysler PT Cruiser
Car AS9076 Upgrade Remote Start to Keyless Entry Logo
65 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
